The ProLite X4071UHSU-B1 is an impressive 4K (3840 x 2160) monitor, offering a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI (dots per inch) the monitor displays an incredibly sharp and crisp image. The VA panel technology offers exceptional color performance, high contrast (5000:1) and wide viewing angles. PIP and PBP features allow users to easily create their own work space by displaying and manipulating multiple applications. USB 3.0 HUB, integrated speakers, headphone socket and hook, ensure compatibility across various devices and media platforms for a real multimedia experience. The ProLite X4071UHSU-B1 suits a massive range of applications including desktop publishing, CAD/CAM drawing, gaming, photographic and web design.
4K
UHD resolution (3840 x 2160), better known as 4K, offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI (dots per inch), it displays an incredibly sharp and crisp image. -
MVA
MVA technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
- iiyama ProLite X4071UHSU-B1 - LED monitor - 40"
- LED-backlit LCD monitor - 40"
- Energy Class
- Class B
- Energy Consumption per Year
- 99 kWh
- Power Consumption (On mode)
- 67.7 W
- USB 3.0 hub
- Panel Type
- MVA
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI1: 60 Hz, HDMI2/MHL: 30 Hz, HDMI3: 30 Hz)
- Pixel Pitch
- 0.229 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 5000:1 / 12000000:1 (dynamic)
- Response Time
- 3 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Input Connectors
- 2xHDMI, HDMI (MHL), VGA, DisplayPort
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 90.65 cm x 23.85 cm x 57.7 cm
- 12.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B, CU
- Display Type
- Energy Class
- Class B
- 99 kWh
- Diagonal Size
- 40"
- Viewable Size
- 39.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.229 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 24 - 75 Hz
- Horizontal Refresh Rate
- 30 - 135 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, sharpness
- OSD Languages
- Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Dutch, Japanese
- Picture in picture, picture by picture, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), X-Res Technology, blue light reduction, i-Style Color
- Black
- 90.65 cm x 23.85 cm x 57.7 cm - with stand
- 12.2 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 6 Watt
- VGA , MHL / HDMI , 2 x HDMI , DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream , Serial input , Audio line-out (mini-jack) , Headphones (mini-jack)
Mechanical
- VESA Mounting Interface
- 400 x 200 mm
- Included Accessories
- Remote control, 2 stands, 2 screws
- Cables Included
- 1 x HDMI cable , 1 x audio cable , 1 x USB cable , 1 x Mini DisplayPort-DisplayPort cable , 1 x DisplayPort cable , 1 x serial cable
- Input Voltage
- 67.7 W
- Power Consumption (Typical)
- 60 Watt
- Power Consumption Stand by
- 0.5 Watt
- OS Required
- Microsoft Windows 95/98/ME/2000/XP/Vista/7/8, Windows 10
- Dimensions & Weight Details
- With stand - width: 90.65 cm - depth: 23.85 cm - height: 57.7 cm - weight: 12.2 kg , Without stand - width: 90.65 cm - depth: 5.2 cm - height: 52.05 cm
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
