iiyama ProLite X3272UHS-B1 32" 3840x2160 3ms HDMI DisplayPort LED Monitor
Quicklinx: DCDRWS00 Mfr#: X3272UHS-B1
Diagonal Size: 31.5in
Max Resolution: 3840 x 2160
Response Time: 3ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
£349.24 ex VAT
£419.08 inc VAT
The ProLite X3272UHS is a 32" 4K monitor capable of displaying 4 times more information than a Full HD screen. It will hence suit a massive range of applications requiring an above average viewable area, like desktop publishing, CAD/CAM drawing, data virtualization, photographic and web design. The VA panel technology offers exceptional color performance, high contrast and wide viewing angles. HDMI, DisplayPort, integrated speakers and a headphone socket ensure compatibility across various devices and media platforms.
  • 4K
    UHD resolution (3840 x 2160), better known as 4K, offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI (dots per inch), it displays an incredibly sharp and crisp image.
  • VA matrix
    VA panel technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Speakers and headphones
    Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
  • OverDrive on/off
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
  • ACR
    Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
iiyama ProLite X3272UHS-B1 - LED monitor - 4K - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class B
Energy Consumption per Year
76 kWh
Power Consumption (On mode)
52 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 60 Hz)
Pixel Pitch
0.181 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 50000000:1 (dynamic)
Response Time
3 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Matte
72.95 cm x 25.4 cm x 54.6 cm
6.8 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B, CU
Display Type
Energy Class
Class B
76 kWh
52 W
Diagonal Size
31.5"
Viewable Size
31.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.181 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
3 ms (grey-to-grey)
Vertical Refresh Rate
24 - 75 Hz
Horizontal Refresh Rate
30 - 135 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Portuguese, Polish, Russian, Spanish, Dutch, Japanese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, i-Style Color
72.95 cm x 25.4 cm x 54.6 cm - with stand
6.8 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort (HDCP) , 2 x DVI (HDCP) , Headphones (mini-jack)
Mechanical
Tilt
Tilt Angle
-4/+12
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), headphone hook
1 x HDMI cable , 1 x DisplayPort cable
52 Watt
Power Consumption Stand by
0.5 Watt
ENERGY STAR Certified
5 °C
35 °C
10 - 80% (non-condensing)
iiyama ProLite X3272UHS-B1 32 Bundle deal on iiyama ProLite X3272UHS-B1 32" 3840x2160 3ms HDMI DisplayPort LED Monitor
£448.41
Response Time: 3ms
Interfaces: HDMI
Brand: iiyama
Price Range Ex VAT: 300 - 500
