iiyama ProLite X2888HS-B2 - LED Monitor 28" 1920 x 1080 VGA/DVI
Quicklinx: CHGCWS00 Mfr#: X2888HS-B2
Diagonal Size: 28in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, Mobile High-Definition Link (MHL) + 1 more
27 in stock
£162.58 ex VAT
£195.09 inc VAT
Capable of displaying 95% of the NTSC color gamut, with the standard for an LCD screen being 72%, the ProLite X2888HS-B2 featuring VA technology offers beyond superb color reproduction. The sophisticated panel technology provides 24 bit True Color support and superior black and white display performance even if you are looking at the screen from the side. The X2888HS-B2 is an ideal screen for demanding users who settle for nothing but amazing image quality.
  • MVA technology
    MVA technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • High color gamut
    Color gamut tells you how large the color range of a monitor is. High color gamut panels can display a wider range of truly deep and vivid colors.
  • Flicker-free + blue light
    The ultimate solution for the comfort and health of your eyes. Flicker-free monitors with blue light reducer function. Absolutely no flickering. And the amount of blue light emitted by the screen and responsible for your eyes feeling fatigued substantially reduced.
  • Speakers and headphones
    Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
iiyama ProLite X2888HS-B2 - LED monitor - Full HD (1080p) - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class B
Energy Consumption per Year
60 kWh
Power Consumption (On mode)
41.4 W
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.32 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort, MHL
Display Position Adjustments
Tilt
66.3 cm x 24.2 cm x 46.35 cm
5.4 kg
DDC-2B, VESA DPMS, TUV Bauart, CU
Display Type
Energy Class
Class B
60 kWh
41.4 W
Diagonal Size
28"
Viewable Size
27.9"
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.32 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
OSD Languages
English, German, French, Polish, Russian, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Overdrive technology, Mobile High-Definition Link (MHL), Advanced Contrast Ratio (ACR), X-Res Technology, 95% NTSC colour gamut, Flicker Free technology, blue light reduction, i-Style Color
5.4 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
VGA , DVI-D (HDCP) , HDMI (HDCP) , DisplayPort (HDCP) , Headphone input
Mechanical
Tilt
Tilt Angle
-3/+20
VESA Mounting Interface
100 x 100 mm
Stand
1 x DVI cable , 1 x audio cable
30 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
iiyama ProLite X2888HS-B2 - LED Monitor 28 Bundle deal on iiyama ProLite X2888HS-B2 - LED Monitor 28" 1920 x 1080 VGA/DVI
£261.75
Diagonal Size: 28in
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: Mobile High-Definition Link (MHL)
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 150 - 300
