iiyama ProLite X2783HSU-B1 27" 1920x1080 AMVA+ LED Black DP USB HUB
Quicklinx: D36GWS00 Mfr#: X2783HSU-B3
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£133.33 ex VAT
£159.99 inc VAT
ProLite X2783HSU is a 27" LED backlit LCD screen featuring AMVA+ panel technology, guarantees accurate and consistent color reproduction with wide viewing angles. Offering 24-bit True Color and great performance for displaying black and white with the 3000:1 native contrast ratio, means that the Prolite X2783HSU will provide excellent performance for photographic, design and web-design.
  • AMVA+
    AMVA+ panel technology offers 24-bit True Color performance and amazing viewing angles.
  • Flicker free + blue light
    The ultimate solution for the comfort and health of your eyes. Flicker free monitors with blue light reducer function. Absolutely no flickering. And the amount of blue light emitted by the screen and responsible for your eyes feeling fatigued substantially reduced.
  • Speakers and headphones
    Playing with friends? Use the integrated high-quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
  • Overdrive on / off
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
iiyama ProLite X2783HSU-B3 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
52 kWh
Power Consumption (On mode)
35.6 W
USB 2.0 hub
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz)
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Matte
62.25 cm x 21.8 cm x 44.6 cm
4.4 kg
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B
3-year warranty
Display Type
Energy Class
Class B
52 kWh
Diagonal Size
27"
Built-in Devices
USB 2.0 hub
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Overdrive technology, TrueColor, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction
62.25 cm x 21.8 cm x 44.6 cm - with stand
4.4 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , HDMI , DisplayPort , Headphones , USB 2.0 upstream , 2 x USB 2.0 downstream
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x USB cable
35.6 W
34 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Drivers & Utilities
Apple MacOS, Microsoft Windows 7 / 8.1 / 10
Dimensions & Weight Details
Without stand - width: 62.25 cm - depth: 5.65 cm - height: 37.25 cm , With stand - width: 62.25 cm - depth: 21.8 cm - height: 44.6 cm - weight: 4.4 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 100 - 150
