ProLite X2783HSU is a 27" LED backlit LCD screen featuring AMVA+ panel technology, guarantees accurate and consistent color reproduction with wide viewing angles. Offering 24-bit True Color and great performance for displaying black and white with the 3000:1 native contrast ratio, means that the Prolite X2783HSU will provide excellent performance for photographic, design and web-design.
AMVA+
AMVA+ panel technology offers 24-bit True Color performance and amazing viewing angles. -
Flicker free + blue light
The ultimate solution for the comfort and health of your eyes. Flicker free monitors with blue light reducer function. Absolutely no flickering. And the amount of blue light emitted by the screen and responsible for your eyes feeling fatigued substantially reduced. -
Speakers and headphones
Playing with friends? Use the integrated high-quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up. -
Overdrive on / off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
- iiyama ProLite X2783HSU-B3 - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 52 kWh
- Power Consumption (On mode)
- 35.6 W
- USB 2.0 hub
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz)
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 12000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Screen Coating
- Matte
- Black
- 62.25 cm x 21.8 cm x 44.6 cm
- 4.4 kg
- Environmental Standards
- TCO Certified Displays 7, ENERGY STAR Qualified
- TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 52 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 4 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Screen Coating
- Matte
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
- HDCP, Eco-Mode, Overdrive technology, TrueColor, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction
- Black
- 62.25 cm x 21.8 cm x 44.6 cm - with stand
- 4.4 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , HDMI , DisplayPort , Headphones , USB 2.0 upstream , 2 x USB 2.0 downstream
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable , 1 x USB cable
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 35.6 W
- 34 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Drivers & Utilities
- OS Required
- Apple MacOS, Microsoft Windows 7 / 8.1 / 10
- Dimensions & Weight Details
- Without stand - width: 62.25 cm - depth: 5.65 cm - height: 37.25 cm , With stand - width: 62.25 cm - depth: 21.8 cm - height: 44.6 cm - weight: 4.4 kg
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - 3 years
