Your basket is empty
iiyama ProLite X2783HSU-B1 27" 1920x1080 4ms VGA DVI-D HDMI LED Monitor
Excellent for photographic & design work!
Quicklinx: 99MTWS00 Mfr#: X2783HSU-B1
ProLite X2783HSU - a 27" LED backlit LCD screen featuring AMVA+ panel technology, guarantees accurate and consistent color reproduction with wide viewing angles. Offering 24 bit 'True Color' and great performance for displaying black and white with the 3000:1 native Contrast Ratio, means that the Prolite X2783HSU will provide excellent performance for photographic, design and web-design. With the added support of a low power LED panel, the iiyama Prolite X2783HSU is also an excellent choice for universities, corporate and financial markets.
Iiyama ProLite X2783HSU-B1 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
52 kWh
Power Consumption (On mode)
25.6 W
USB Hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 5000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
62.25 cm x 21.8 cm x 44.6 cm
4.4 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, VESA DPMS, PSE Mark, TCO Displays, VCCI Class B
Display Type
Energy Class
Class B
52 kWh
25.6 W
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB Hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, colour balance, input select, phase, clock
OSD Languages
English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
4.4 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D , HDMI , Headphones , USB upstream , 2 x USB downstream
Mechanical
Tilt
Tilt Angle
-5/+22
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
Power Supply
Internal
34 Watt
Power Consumption Stand by
0.5 Watt
Apple MacOS, Microsoft Windows 95/98/ME/2000/XP, Microsoft Windows Vista / 7 / 8
ENERGY STAR Certified
99MT C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
99MT C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.76
99MT C2G 5m Select High Speed HDMI with Ethernet In Stock £15.70
99MT C2G 10m Select High Speed HDMI with Ethernet In Stock £30.15
99MT C2G 15m Select High Speed HDMI with Ethernet In Stock £40.84
99MT C2G Pro HDMI to VGA Converter In Stock £46.35
