iiyama Prolite X2485WS-B3 24" 1920x1200 VGA DisplayPort LED Monitor
Quicklinx: CC1WWS00 Mfr#: X2485WS-B3
ProLite X2485WS features an IPS technology LED panel offering accurate and consistent color reproduction with wide viewing angles and fast response time. The ProLite X2485WS is a 16:10 monitor with 1920 x 1200 native screen resolution. An array of inputs including Display Port, DVI and VGA connections ensure compatibility across a range of devices including games consoles and work stations. It also has two integrated stereo speakers and is VESA mount compatible.
  • IPS technology
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Blue light reducer
    Looking at a monitor screen for several hours per day, especially form a closer distance, causes eye fatigue. This effect is much stronger with computer screens than with TV equipment. One of the factors responsible for this phenomenon is the blue light emitted by the screen. Therefore reducing the amount of blue light ultimately allows eyes to feel less tired while working long hours with a computer screen. It was achieved by adjusting the monitor's brightness and color temperature through a feature called "Blue light reduction" easily accessible through the monitor's OSD menu.
  • Speakers and headphones
    Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
iiyama ProLite X2485WS-B3 - LED monitor - 24.1"
LED-backlit LCD monitor - 24.1"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Tilt
Voltage
56.1 cm x 21.65 cm x 44.9 cm
4.8 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, DDC-2B, VESA DPMS, VCCI Class B, CU
Display Type
Diagonal Size
24.1"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 94 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Russian, Spanish, Dutch, Japanese, Chinese
Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), blue light reduction
56.1 cm x 21.65 cm x 44.9 cm - with stand
4.8 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
VGA , DVI-D , DisplayPort , Headphones
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Stand
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
Input Voltage
Power Consumption (Typical)
24 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Microsoft Windows 95/98/ME/2000/XP/Vista/7/8/10
Dimensions & Weight Details
With stand - width: 56.1 cm - depth: 21.65 cm - height: 44.9 cm - weight: 4.8 kg , Without stand - width: 56.1 cm - depth: 5.1 cm - height: 38 cm
Sustainability Information
ENERGY STAR Certified
CC1W C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £12.92
