iiyama ProLite X2483HSU-B2 24" 4ms VGA DVI-D HDMI LED Monitor
Quicklinx: CB0BWS00 Mfr#: X2483HSU-B2
ProLite X2483HSU-B2 - a 24" LED backlit LCD screen featuring AMVA panel technology, guarantees accurate and consistent color reproduction with wide viewing angles. Offering great performance for displaying black and white with optimal Native Contrast Ratio, means that the Prolite X2483HSU-B2 will provide excellent performance for photography, design and web design. With the added support of a low power LED panel, the Iiyama Prolite X2483HSU-B2 is also an excellent choice for universities, corporate and financial markets.
  • Flicker Free technology + blue light reduction
    The ultimate solution for the comfort and health of your eyes. Flicker free monitors with blue light reducer function. And the amount of blue light emitted by the screen and responsible for your eyes feeling fatigued substantially reduced.
  • AMVA
    AMVA technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Overdrive on / off
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the Overdrive feature will eliminate that.
  • ACR
    Advanced Contrast Ratio automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen.
iiyama ProLite X2483HSU-B2 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
USB 2.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Voltage
55.25 cm x 20.3 cm x 40.65 cm
3.9 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B, CU
Display Type
Energy Class
Class B
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 2.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction
3.9 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D , HDMI , 2 x USB 2.0 downstream , USB 2.0 upstream , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
Input Voltage
Power Consumption (Typical)
26 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Drivers & Utilities
Microsoft Windows 95/98/ME/2000/XP, Microsoft Windows Vista / 7 / 8 / 10
Sustainability Information
ENERGY STAR Certified
CB0B C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
