Your basket is empty
iiyama ProLite X2483HSU-B2 24" 4ms VGA DVI-D HDMI LED Monitor
Quicklinx: CB0BWS00 Mfr#: X2483HSU-B2
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
£126.16 ex VAT
£151.39 inc VAT
ProLite X2483HSU-B2 - a 24" LED backlit LCD screen featuring AMVA panel technology, guarantees accurate and consistent color reproduction with wide viewing angles. Offering great performance for displaying black and white with optimal Native Contrast Ratio, means that the Prolite X2483HSU-B2 will provide excellent performance for photography, design and web design. With the added support of a low power LED panel, the Iiyama Prolite X2483HSU-B2 is also an excellent choice for universities, corporate and financial markets.
Iiyama ProLite X2483HSU-B2 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
USB 2.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
55.25 cm x 20.3 cm x 40.65 cm
3.9 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, DDC-2B, VESA DPMS, PSE Mark, TCO Displays, VCCI Class B, CU
Display Type
Energy Class
Class B
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 2.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction
3.9 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D , HDMI , 2 x USB 2.0 downstream , USB 2.0 upstream , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+22
Flat Panel Mount Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
26 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Drivers & Utilities
Microsoft Windows 95/98/ME/2000/XP, Microsoft Windows Vista / 7 / 8 / 10
ENERGY STAR Certified
CB0B C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £6.63
CB0B C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.42
CB0B C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL In Stock £8.29
CB0B C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
CB0B C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £7.11
CB0B C2G 2m HDMI to DVI-D Digital Video Cable In Stock £7.03
CB0B C2G Pro DVI-D to VGA Converter - Video converter - Black In Stock £47.00
Diagonal Size: 24in
Response Time: 4ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 100 - 150
