ProLite XB2483HSU-B2DP - a 24" LED backlit LCD screen featuring AMVA panel technology, delivers accurate and consistent color reproduction with wide viewing angles. Offering 24 bit 'True Color' and great performance for displaying black and white with the 3000:1 Native Contrast Ratio, means that the Prolite XB2483HSU-B2DP will provide excellent performance for photographic, design and web-design. The monitor features a height adjustable stand with PIVOT function making it also an excellent choice for universities, corporate and financial markets.
HAS + PIVOT
With a height adjustable stand you will create an ergonomic work posture and position that meets all health and safety requirements. This will not only prevent any health issues but will also increase your productivity. The pivot function allows the screen to rotate from landscape to portrait orientation. This functionality can be useful if the application requires more height than width. -
AMVA
AMVA technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
Flicker free + blue light
The ultimate solution for the comfort and health of your eyes. Flicker free monitors with blue light reducer function. Absolutely no flickering. And the amount of blue light emitted by the screen and responsible for your eyes feeling fatigued substantially reduced. -
Overdrive on / off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. -
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
- iiyama ProLite XB2483HSU-B2DP - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- USB 2.0 hub
- Panel Type
- A-MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.275 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 12000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 55.25 cm x 23 cm x 38.1 cm
- 5.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, DDC-2B, VESA DPMS, DDC/CI, PSE Mark, VCCI Class B, CU
- Display Type
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- A-MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.275 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 4 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
- HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), Flicker Free technology
- Black
- 55.25 cm x 23 cm x 38.1 cm - with stand
- 5.6 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , DVI-D , DisplayPort , Headphones (mini-jack) , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , Audio line-in (mini-jack)
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable , 1 x DisplayPort cable
- Input Voltage
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Driver
- OS Required
- Microsoft Windows 95/98/ME/2000/XP/Vista/7/8/10
- Dimensions & Weight Details
- Without stand - width: 55.25 cm - depth: 5.65 cm - height: 33.4 cm , With stand - width: 55.25 cm - depth: 23 cm - height: 38.1 cm - weight: 5.6 kg
Sustainability Information
- ENERGY STAR Certified
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
