iiyama ProLite X2283HS-B3 22" 1920x1080 4ms VGA HDMI DisplayPort LED Monitor
Quicklinx: FJ0NWS00 Mfr#: X2283HS-B3
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
30 in stock
£82.31 ex VAT
£98.77 inc VAT
The ProLite X2283HS is an excellent Full HD LED-backlit monitor with resolution and VA panel technology guaranteeing accurate and consistent color reproduction with wide viewing angles. Triple input support ensures compatibility with the installed graphics card and embedded Notebook outputs. The X2283HS is also equipped with two high quality stereo speakers. This monitor is a reliable solution for both home and office use.
  • Flicker free
    Controlling the monitor's brightness through electric current has allowed eliminating the screen flicker. You can easily test it yourself - just look at the screen via you smartphone's camera. Your eyes will love it.
  • Overdrive on/off
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
  • Speakers and headphones
    Use the integrated high quality speakers. Plug your headset to the headphone socket and turn the volume up.
  • ACR
    Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • VESA
    VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard.
  • VA matrix
    VA panel technology offers higher contrast and much better viewing angles. The screen will look good no matter what angle you look at it.
iiyama ProLite X2283HS-B3 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
19 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
50.5 cm x 19.3 cm x 38.25 cm
3 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B, CU
3-year warranty
Display Type
Energy Class
Class A
28 kWh
19 W
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), Flicker Free technology
50.5 cm x 19.3 cm x 38.25 cm - with stand
3 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , HDMI , DisplayPort , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
21 Watt
ENERGY STAR Certified
Limited warranty - 3 years - on-site
Diagonal Size: 22in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 50 - 100
