Incorporating the InfraRed 10-point touch feature along with supreme AMVA3 panel color performance, this display offers the optimum performance for a truly multi-user interactive experience. With the ability to handle up to 10 individual touch points, the TH5564MIS offers an exceptional capacity within retail, education, training, corporate and B2B markets. Features include PIP and PBP perfect for video conferencing or handing multi-input content in many environments. It also features an ambient light sensor delivering optimal picture quality with the added benefit of saving on power. Incorporating protection glass and AG-coating the display can handle harshest environments from the classroom to public domain retail installation. Landscape and portrait friendly, this is a perfect solution for interactive digital signage.
- iiyama ProLite TH5565MIS-W1AG 55" Class (54.6" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Commercial Use
- Yes - digital signage
- White
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, sticker
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 106 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 126.56 cm x 7.2 cm x 73.65 cm
- 37.5 kg
- Product Type
- Energy Class
- Class B
- 106 Watt
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Commercial Use
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- Modes
- Portrait mode, landscape mode
- Design
- Fanless Design
- Protection
- Protection glass
- Dimensions
- Without stand
- 126.56 cm
- 7.2 cm
- 73.65 cm
- 37.5 kg
- Enclosure Colour
- White
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-glare, 7H Hard
- Image Contrast Ratio
- 1100:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 20
- Response Time
- 12 ms
- Display Menu Language
- Czech, English, German, French, Polish, Russian, Japanese
- Infrared multitouch technology, Daisy Chain
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- USB Port
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- Audio input , Audio input , VGA input , 3 x HDMI input , Composite video input , USB , HDMI output , Component video output , Audio line-in , Audio line-out , Audio line-in , Remote control , LAN , Infrared (IrDA) , S-Video input , Component video input , Component video output
- Sticker
- Cables Included
- VGA cable , HDMI cable , USB cable
- DDC-2B, VESA DPMS, CB, TUV Bauart, CU
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
