iiyama ProLite TH4265MIS-B1AG 42" IR Touch USB DVI VGA HDMI
Quicklinx: CNJZWS00 Mfr#: TH4265MIS-B1AG
Select:
  • 42"
  • 1080p (Full HD)
More than 50 in stock
£1,014.44 ex VAT
£1,217.32 inc VAT
ProLite TH4265MIS-B1AG is a 42" Full HD, professional and fan-less LED-backlit display. Incorporating the InfraRed 20 point touch feature along with the supreme AMVA3 panel color performance, this display offers the optimum performance for a truly multi-user interactive display experience. The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. Besides, it features an ambient light sensor delivering exceptional performance with the added benefit of saving on power. Landscape and Portrait friendly, the display can be mounted according to the application for true impact in Interactive Digital Signage and with Protection Glass the display can handle harshest environments from the Classroom to Public Domain Retail installation.
  • AMVA3
    AMVA3 technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Touch technology - infrared
    The infrared technology uses infrared backlight. A touch event is registered with great accuracy when the infrared light is blocked by finger or stylus. This technology does not rely on an overlay or substrate, so it is impossible to physically "wear out" the touchscreen. Moreover the display characteristics remain virtually unaffected by the touch functionality.
  • DisplayPort/HDMI daisy chain support
    A daisy chain is a wiring scheme in which multiple devices are wired together in sequence or in a ring. It enables a connection of a series of devices using a single connection between each two devices, using DisplayPort/HDMI input and a DisplayPort/HDMI output. The output connects to the next downstream display. This cabling arrangement, with one DisplayPort/HDMI cable between each set of monitors, provides a simple, less cluttered system configuration.
  • USB playback
    The monitor supports playback of presentations, video and almost any type of content stored on the USB device or internal memory.
  • AG coating
    The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
iiyama ProLite TH4265MIS-B1AG 42" LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
42"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
AMVA3
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
2 ports
Remote Control
Standard remote
Voltage
AC 100 - 240 V (50/60 Hz)
Energy Class
Class B
75 Watt
Power Consumption (On mode)
75.3 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
110 kWh
98.7 cm x 7.45 cm x 57.8 cm
24.6 kg
Energy Class
Class B
75 Watt
75.3 W
110 kWh
Diagonal Class
42"
Commercial Use
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
Modes
Portrait mode, landscape mode
Protection
Protection glass
Cooling System
Fanless
98.7 cm
7.45 cm
57.8 cm
24.6 kg
Enclosure Colour
Display
LCD Display Technology
AMVA3
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare, 7H Hard
Image Contrast Ratio
3000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
20
Response Time
6.5 ms
Display Menu Language
Czech, English, German, French, Italian, Russian, Spanish, Dutch, Japanese
Multitouch, infrared multitouch technology, Daisy Chain
Stands & Mounts
VESA Mounting Interface
400 x 400 mm
Media Player
Supported Video Formats
MPEG-4, Xvid, DivX, ASF, AVI, MKV, MOV, FLV, RM, 3GPP, F4V, MPG, MPEG
Supported Audio Formats
MP3, WMA, WAV, MP4, MKA
Supported Pictures Formats
BMP, PNG, JPEG
USB Port
USB Ports Qty
2
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - built-in - 10 Watt
Connector Type
VGA input , 3 x HDMI input , Component video input , HDMI output , USB , Composite video input , Component video output , Audio input , Audio input , Audio output , 2 x USB 2.0 , Serial output , Serial input , LAN , Remote control input , Remote control output
Cable ties, batteries, 3 x touch pens, logo sticker
VGA cable , HDMI cable , USB cable
DDC-2B, VESA DPMS, CB, TUV Bauart, CU
Power supply
Nominal Voltage
0.5 Watt
0 - 85% (non-condensing)
Brand: iiyama
Price Range Ex VAT: 1000 - 1500
