iiyama ProLite TH4264MIS-B2AG 42" 1920x1080 9ms VGA DVI HDMI DisplayPort LED Large Format Display
Quicklinx: BRNRWS00 Mfr#: TH4264MIS-B2AG
  • 1080p
Incorporating the InfraRed 10 point touch feature along with supreme panel color performance, this display offers the optimum performance for a truly multi-user interactive display experience. The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks. Features include PIP and PBP perfect for Video Conferencing or handing multi-input content in many environments.
  • Touch technology - infrared
    The infrared technology uses infrared backlight. A touch event is registered with great accuracy when the infrared light is blocked by finger or stylus. This technology does not rely on an overlay or substrate, so it is impossible to physically "wear out" the touchscreen. Moreover the display characteristics remain virtually unaffected by the touch functionality.
  • IPS
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • AG coating
  • PIP
    PIP (Picture in Picture) function allows you to watch images coming from two different sources at the same time.
  • Light sensor
    The ambient light sensor detects changes in environmental lighting conditions and automatically adjusts the screens backlight brightness to compensate for an increase or decrease in light.
iiyama ProLite TH4264MIS-B2AG 42" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
42"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control, pen stylus
Voltage
Energy Class
Class C
120 Watt
Power Consumption Stand by
0.5 Watt
99 cm x 12.2 cm x 58.45 cm
23.6 kg
Energy Class
Class C
120 Watt
Diagonal Class
42"
Commercial Use
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode
99 cm
12.2 cm
58.45 cm
23.6 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare
Colour Depth
16.7 million colours
Image Contrast Ratio
1000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.4833mm x 0.4833mm
Touchpoints Qty
10
Response Time
9 ms
Colour Temperature Control
Infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Remote Control
Remote control
Audio System
Audio Controls
Balance, bass, treble
Speaker System
2 speakers
Output Power / Total
24 Watt
Speakers
2 x speaker - 12 Watt
Connector Type
VGA input , DVI-D input , HDMI input , Serial output , Composite video input , S-Video input , Audio input , 2 x audio input , Component video input , Speakers output , Serial input , USB , VGA output , Composite video output , Audio output , LAN
Pen stylus
VGA cable , DVI cable , USB cable
Plug and Play, DDC-2B, VESA DPMS, CB, TUV Bauart
Power supply
Input Voltage
0.5 Watt
On / Off Switch
