iiyama ProLite TF6538UHSC-B1AG 65" 3840x2160 8ms VGA DVI HDMI DisplayPort LED Large Format Display
Quicklinx: DVMKWS00 Mfr#: TF6538UHSC-B1AG
TV Tuner Presence: No
Video Interface: HDMI
£3,112.94 ex VAT
£3,735.52 inc VAT
The TF6538UHSC is the ideal interactive display solution for education, kiosks, interactive digital signage and in-store communications. The touch technology with many touch points ensures a seamless and accurate touch response. Featuring a metal housing with ball-drop proof, scratch-resistant, edge-to-edge glass and an IPS panel, this display can be used in landscape, portrait and face-up orientation in demanding environments for maximum flexibility and accessibility.
iiyama ProLite TF6538UHSC-B1AG 65" Class (64.5" viewable) LED display - 4K
LED-backlit LCD flat panel display with touchscreen (multi touch)
Diagonal Class
65"
Diagonal Size
64.5"
Commercial Use
Yes - interactive digital signage
Matte black
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Frame Rate & Enhancement Technology
60 Hz Frame Rate
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote control, batteries, cable cover, mini-PC bracket
Voltage
AC 120/230 V (50 - 60 Hz)
Energy Class
Class A
145 Watt
Power Consumption (On mode)
131 W
Power Consumption Stand by
1 Watt
Energy Consumption per Year
191 kWh
153.04 cm x 6.76 cm x 90.56 cm
59.8 kg
Energy Class
Class A
145 Watt
131 W
191 kWh
Diagonal Class
65"
Diagonal Size
64.5"
Commercial Use
Combined With
Touchscreen (multi touch)
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
Modes
Portrait mode, landscape mode, Face-up Mode
Design
Open Frame
Dimensions
Without stand
153.04 cm
6.76 cm
90.56 cm
59.8 kg
Enclosure Colour
Matte black
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Frame Rate
LED backlight
Coating
Anti-glare
Image Contrast Ratio
1100:1
Brightness
500 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Touchpoints Qty
50
Response Time
8 ms
Display Menu Language
English, German, French, Italian, Polish, Russian, Spanish, Dutch
Operation Hours / Days
24 / 7
Key lock, Palm Rejection, designed for 24/7 operation, ball drop test proof, scratch-resistant, edge-to-edge glass
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
Remote Control
Remote control
Projected capacitive touchscreen
Audio System
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x main channel speaker - 8 Watt
Network & Internet Multimedia
LAN
Connector Type
VGA input , DisplayPort input , DVI-D input , 2 x HDMI input , Audio input , RS-232 input , LAN , Audio output , USB , Remote control
Batteries, cable cover, mini-PC bracket
USB cable , HDMI cable , DisplayPort cable , IR extender cable
Plug and Play, DDC-2B, CB, cULus, TUV Bauart, CU, DisplayPort 1.2
Power supply
Nominal Voltage
1 Watt
Width (Shipping)
167 cm
Depth (Shipping)
31 cm
Height (Shipping)
102 cm
Brand: iiyama
Price Range Ex VAT: 1500+
