Product
iiyama ProLite TF5538UHSC-B1AG 55"3840x2160 LED Interactive Display - Black
Quicklinx: DKKCWS00 Mfr#: TF5538UHSC-B1AG
£2,005.56 ex VAT
£2,406.67 inc VAT
Marketing description is not available.
  • Capacitive touch technology
    This technology uses a sensor grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when a human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with a human finger (also latex gloved) and a stylus pen.
  • Open-frame LFD
    Open-frame monitors are an ideal solution for kiosk integrators and in-store retail.
  • 24/7 operation
    24/7 displays are designed for a continuous operation.
  • Anti-Glare coating
    The Anti-Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
  • Ball-drop-test-proof
    The ball-drop-test uses a half-kilo steel ball, which is dropped onto the touch screen from a height of 1.3 meter. If the touch screen surface remains unaffected, the monitor passes the ball-drop-test for high impact resistance and durability.
iiyama ProLite TF5538UHSC-B1AG 55" Class (55" viewable) LED display
LED-backlit LCD flat panel display with touchscreen (multi touch)
Diagonal Class
55"
Diagonal Size
55 in
Commercial Use
Yes - digital signage / interactive communication
Matte black
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Motion Enhancement Technology
60 Hz Frame Rate
Video Interface
HDMI
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
AC 120/230 V (50 - 60 Hz)
Energy Class
Class A
120 Watt
Power Consumption (On mode)
120 W
129.45 cm x 6.8 cm x 76.5 cm
41 kg
Energy Class
Class A
120 Watt
120 W
Diagonal Class
55"
Diagonal Size
55 in
Commercial Use
Combined with
Touchscreen (multi touch)
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
PC Interface
Modes
Portrait mode, landscape mode, Face-up Mode
Design
Open Frame
Dimensions
Without stand
129.45 cm
6.8 cm
76.5 cm
41 kg
Enclosure Colour
Matte black
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Frame Rate
LED backlight
Image Contrast Ratio
1100:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
12
Response Time
8 ms
Display Menu Language
English, German, French, Italian, Polish, Russian, Spanish, Dutch
Operation Hours / Days
24 / 7
Palm Rejection, designed for 24/7 operation, ball drop test proof, scratch-resistant, edge-to-edge glass
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
Remote Control
Standard remote
Projected capacitive touchscreen
Audio System
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x main channel speaker - built-in - 8 Watt
Network & Internet Multimedia
LAN
Connector Type
VGA input , DisplayPort input , DVI-D input , 2 x HDMI input , Audio input , RS-232 input , LAN , Audio output , USB
Batteries
USB cable , HDMI cable , DisplayPort cable , IR extender cable
Plug and Play, DDC-2B, CB, cULus, TUV Bauart, CU, DisplayPort 1.2
Power supply
Nominal Voltage
Power Consumption Stand by
1 Watt
Width (Shipping)
140 cm
Depth (Shipping)
24.5 cm
Height (Shipping)
93 cm
Brand: iiyama
Price Range Ex VAT: 1500+
