The 4K Ultra HD (3840 x 2160) open-frame TF4938UHSC is the ideal interactive display solution for education, kiosks, interactive digital signage and in-store communications. The Projective Capacitive (PCAP) touch technology with 12 touch points ensures a seamless and accurate touch response. Featuring a metal housing with 60950-1 ball-drop proof, scratch-resistant, edge-to-edge glass and an IPS panel; this display can be used in landscape, portrait and face-up orientation in the demanding environments for maximum flexibility and accessibility. Either as a standalone wall mounted solution or built-in a desk or kiosk thanks to its open-frame mounting holes.
Capacitive touch technology
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen. -
Open-frame LFD
Open-frame monitors are an ideal solution for kiosk integrators and instore retail. -
24/7
24/7 displays are designed for a continuous operation. -
AG coating
The anti- glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
- iiyama ProLite TF4938UHSC-B1AG 49" Class (48.5" viewable) LED-backlit LCD display - 4K - for digital signage / interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen (multi touch)
- Diagonal Class
- 49"
- Diagonal Size
- 48.5"
- Commercial Use
- Yes - interactive digital signage
- Matte black
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Frame Rate & Enhancement Technology
- 60 Hz Frame Rate
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50 - 60 Hz)
- Energy Class
- Class B
- 115 Watt
- Power Consumption (On mode)
- 115 W
- Power Consumption Stand by
- 1 Watt
- Dimensions (WxDxH) - without stand
- 115.4 cm x 7.35 cm x 68.4 cm
- 30 kg
- Product Type
- Energy Class
- Class B
- 115 Watt
- 115 W
- Diagonal Class
- 49"
- Diagonal Size
- 48.5"
- Commercial Use
- Combined With
- Touchscreen (multi touch)
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- Modes
- Portrait mode, landscape mode, Face-up Mode
- Design
- Open Frame
- Dimensions
- Without stand
- 115.4 cm
- 7.35 cm
- 68.4 cm
- 30 kg
- Enclosure Colour
- Matte black
Display
- LCD Display Technology
- IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- 60 Hz Frame Rate
- LED backlight
- Coating
- Anti-glare, 7H Hard
- Image Contrast Ratio
- 1100:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 12
- Response Time
- 8 ms
- Display Menu Language
- English, German, French, Italian, Polish, Russian, Spanish, Dutch
- Operation Hours / Days
- 24 / 7
- Key lock, Palm Rejection, designed for 24/7 operation, ball drop test proof, scratch-resistant, edge-to-edge glass
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 200 mm
Media Player
- USB Port
Remote Control
- Remote control
- Projected capacitive touchscreen
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 16 Watt
- Speakers
- 2 x main channel speaker - 8 Watt
- Connector Type
- VGA input , DisplayPort input , DVI-D input , 2 x HDMI input , Audio input , Serial , LAN , Audio output , USB , Remote control
- Batteries
- Cables Included
- USB cable , HDMI cable , DisplayPort cable
- Plug and Play, DDC-2B, CB, cULus, TUV Bauart, CU, DisplayPort 1.2
- Power Device
- Power supply
- Input Voltage
- 1 Watt
- On / Off Switch
- 0 °C
- 40 °C
- 90% (non-condensing)
