iiyama Prolite TF4938UHSC 49" 3840x2160 DVI VGA HDMI LED Large Format Display
Quicklinx: FQ3LWS00 Mfr#: TF4938UHSC-B2AG
TV Tuner Presence: No
Video Interface: HDMI
29 in stock
£1,937.65 ex VAT
£2,325.18 inc VAT
The 4K Ultra HD (3840 x 2160) Open Frame TF4938UHSC monitor is the ideal interactive display solution for education, kiosks, interactive digital signage and in-store communications. The Projective Capacitive (PCAP) touch technology with 15 touch points ensures a seamless and accurate touch response. Featuring a metal housing with 60950-1 ball-drop-proof, scratch-resistant, edge-to-edge glass and an IPS panel; this display can be used in landscape, portrait and face-up orientation in the most demanding environments for maximum flexibility and accessibility. Either as a stand-alone wall mounted solution or built-in a desk or kiosk thanks to its Open Frame mounting holes.
  • Open frame LFD
    Open frame monitors feature special mounting screw holes on all sides of the monitor that can be used for installing the monitor. Open Frame monitors are an ideal solution for kiosk integrators and in-store retail.
  • Projective Capacitive technology
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen.
  • Touch through glass
    This through glass touch screen works right through glass and can turn glass surfaces into an interactive touch screen display. Use it on storefront windows, real estate office, in-store for POS or restaurants.
  • 24/7 display
    24/7 displays are designed for a continuous operation.
  • AG coating
    The anti-glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
iiyama ProLite TF4938UHSC-B2AG 49" Class (48.5" viewable) LED-backlit LCD display - 4K
LED-backlit LCD flat panel display with touchscreen (multi touch)
Diagonal Class
49"
Diagonal Size
48.5"
Commercial Use
Yes - interactive digital signage
Matte black
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Frame Rate & Enhancement Technology
60 Hz Frame Rate
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote control, batteries, cable cover, mini-PC bracket
Voltage
AC 120/230 V (50 - 60 Hz)
Energy Class
Class C
135 Watt
Power Consumption (On mode)
135 W
Power Consumption Stand by
1 Watt
Energy Consumption per Year
197 kWh
115.4 cm x 7.35 cm x 68.4 cm
33.3 kg
Energy Class
Class C
135 Watt
135 W
197 kWh
Diagonal Class
49"
Diagonal Size
48.5"
Commercial Use
Combined With
Touchscreen (multi touch)
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
Modes
Portrait mode, landscape mode, Face-up Mode, kiosk mode
Design
Open Frame
Dimensions
Without stand
115.4 cm
7.35 cm
68.4 cm
33.3 kg
Enclosure Colour
Matte black
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Frame Rate
LED backlight
Coating
Anti-glare, 7H Hard
Image Contrast Ratio
1100:1
Brightness
500 cd/m²
Total Pixels
8,300,000
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
15
Response Time
8 ms
Display Menu Language
English, German, French, Italian, Polish, Russian, Spanish, Dutch
Operation Hours / Days
24 / 7
Key lock, Palm Rejection, designed for 24/7 operation, ball drop test proof, edge-to-edge glass
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
VESA Compatibility
Media Player
USB Port
Remote Control
Remote control
Projected capacitive touchscreen
Audio System
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x main channel speaker - 8 Watt
Network & Internet Multimedia
LAN
Connector Type
VGA input , DisplayPort input , DVI-D input , 2 x HDMI input , Audio input , RS-232C input , LAN , Audio output , USB , Remote control
Batteries, cable cover, mini-PC bracket
USB cable , HDMI cable , DisplayPort cable , IR extender cable
Plug and Play, DDC-2B, cULus, IP54, TUV Bauart, EAC, REACH SvHC
Power supply
Input Voltage
1 Watt
Power Consumption (Off Mode)
1 Watt
On / Off Switch
Width (Shipping)
128 cm
Depth (Shipping)
24.5 cm
Height (Shipping)
83.5 cm
Weight (Shipping)
34 kg
Brand: iiyama
Price Range Ex VAT: £1500+
Stock Status: In stock
