iiyama ProLite TF4338MSC-B1AG 43" 1920x1080 Interactive Display
Quicklinx: DFYTWS00 Mfr#: TF4338MSC-B1AG
TV Tuner Presence: No
Video Interface: HDMI
  • 1080p (Full HD)
£1,203.53 ex VAT
£1,444.23 inc VAT
The Full HD Open Frame TF4338MSC is the ideal interactive display solution for education, kiosks, interactive digital signage and in-store communications. The Projective Capacitive (PCAP) touch technology with 12 touch points ensures a seamless and accurate touch response. Featuring a metal housing with 60950-1 ball-drop proof, scratch-resistant, edge-to-edge glass and an IPS panel; this display can be used in landscape, portrait and face-up orientation in the most demanding environments for maximum flexibility and accessibility.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen.
  • Open frame
    Open frame monitors are an ideal solution for kiosk integrators and instore retail.
  • AG coating
    The anti-glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
iiyama ProLite TF4338MSC-B1AG 43" Class (42.5" viewable) LED display
LED-backlit LCD flat panel display with touchscreen (multi touch)
Diagonal Class
43"
Diagonal Size
42.5"
Commercial Use
Yes - interactive digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
Energy Class
Class A
75 Watt
98.75 cm x 6.8 cm x 58.77 cm
21.6 kg
Energy Class
Class A
75 Watt
Diagonal Class
43"
Diagonal Size
42.5"
Commercial Use
Combined With
Touchscreen (multi touch)
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
Modes
Portrait mode, landscape mode, Face-up Mode
Design
Open Frame
Dimensions
Without stand
98.75 cm
6.8 cm
58.77 cm
21.6 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare, 7H Hard
Image Contrast Ratio
1100:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
12
Response Time
12 ms
Display Menu Language
English, German, French, Italian, Polish, Russian, Spanish, Dutch
Palm Rejection, Projected Capacitive Touch (PCT), designed for 24/7 operation, ball drop test proof
Stands & Mounts
VESA Mounting Interface
400 x 200 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x main channel speaker - built-in - 8 Watt
Connector Type
VGA input , DVI-D input , 2 x HDMI input , DisplayPort , Audio input , Audio output , LAN , RS-232C , USB
Cable cover
HDMI cable , DisplayPort cable , USB cable , IR extender cable
DDC-2B, VESA DPMS, CB, cULus, IP54, TUV Bauart, CU
Power supply
Nominal Voltage
Brand: iiyama
Price Range Ex VAT: 1000 - 1500
