With Full HD resolution and Projective Capacitive 10-point touch technology, the ProLite TF2738MSC-B1 delivers seamless and accurate touch response. Featuring AMVA+ LED LCD screen technology, it offers exceptional color performance and wide viewing angles. Its rugged bezel with edge-to-edge glass makes it very suitable for applications like table top integration. Equipped with speakers, DVI, HDMI and DisplayPort inputs for multiple connecting possibilities. The ProLite TF2738MSC-B1 is an ideal screen for kiosk integrators and a perfect solution for interactive digital signage, instore retail, gaming and interactive presentations.
AMVA+
AMVA+ Panel technology offers 24-bit True Color performance and amazing viewing angles. -
Touch technology - capacitive
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen. -
Open frame LFD
Open frame monitors are an ideal solution for kiosk integrators and instore retail. -
Scratch resistance
Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched. -
Speakers
This LED monitor is equipped with two high-quality stereo speakers.
- iiyama ProLite TF2738MSC-B1 - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27" - touchscreen
- Energy Class
- Class A
- Energy Consumption per Year
- 44 kWh
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.31125 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 12000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey), 12 ms (typical)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, DisplayPort
- Screen Coating
- 6H Hard Coating
- Voltage
- AC 100 - 240 V (50/60 Hz)
- Black
- 64.85 cm x 5 cm x 38.65 cm
- 7.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, DDC-2B, VESA DPMS, cULus, TUV Bauart, IPX1, CU
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 44 kWh
- Diagonal Size
- 27"
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.31125 mm
- Brightness
- 300 cd/m²
- Brightness w/touchscreen
- 255 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Screen Coating
- 6H Hard Coating
- Backlight Technology
- LED backlight
- OSD Languages
- English, German, French, Polish, Russian, Dutch, Japanese, Chinese
- HDCP, Eco-Mode, tempered glass, Advanced Contrast Ratio (ACR), edge-to-edge glass, X-Res Technology, scratch-resistant, Projected Capacitive Touch (PCT) technology, blue light reduction, i-Style Color, Wide Viewing Angle
- Black
- 7.7 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
Input
- Touchscreen
- Movement Detection Technology
- Capacitive
- DVI-D , HDMI , DisplayPort , Headphones (mini-jack) , USB
Mechanical
- VESA Mounting Interface
- 200 x 100 mm
- Water-resistant, dust-resistant, fanless, rugged, portrait / landscape mode
- Included Accessories
- Cable management cover
- Cables Included
- 1 x HDMI cable , 1 x DisplayPort cable , 1 x DisplayPort cable - miniDisplayPort to DisplayPort , 1 x USB cable
- Input Voltage
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Driver
- OS Required
- Apple MacOS, Linux, Apple MacOS X, Android, Microsoft Windows 7 / 8 / 10
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
