ProLite TF2234MC uses Projective Capacitive Touch technology, built into an eye catching bezel with edge-to-edge glass. Featuring IPS LCD Screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for Interactive Digital Signage. In addition to the superb image quality, the screen comes with an IP54 Rating, making it dust and water resistant and with a rugged bezel making it suitable for demanding environments. The ProLite TF2234MC is the ideal screen for the kiosk integrators and a solution for interactive digital signage, instore retail, gaming and interactive presentations.
Full HD
With true 1920 x 1080p resolution this LFD is ready to display high definition images. This means it can accommodate more information on the screen. -
IPS
IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
Touch technology-capacitive
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball. -
VESA
VESA mount compliance means you can easily mount the touchscreen to any mounting that complies with the VESA standard. -
Key lock
You can easily lock and unlock the controls preventing unauthorized changes to settings you made.
- iiyama ProLite TF2234MC-B1X - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5" - touchscreen
- Touch-screen
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.247 mm
- Brightness
- 225 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 8 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Screen Coating
- 7H Hard Coating
- Voltage
- DC 12 V
- Black
- 51.75 cm x 4.6 cm x 31.35 cm
- 4.4 kg
- VCCI, VESA DPMS, IP54, TUV Bauart
- Display Type
- Diagonal Size
- 21.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.247 mm
- Brightness
- 225 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 8 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 31.5 - 82.3 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Screen Coating
- 7H Hard Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, input select, colour temperature, phase, H-size
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
- Edge-to-edge glass, HID Compliant, Projected Capacitive Touch (PCT) technology
- Black
- 4.4 kg
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- DVI-D , VGA , USB
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Water-resistant, dust-resistant
- Cables Included
- 1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x USB cable
- Power Supply
- External
- Input Voltage
- DC 12 V
- Power Consumption (Typical)
- 27 Watt
