Your basket is empty
iiyama ProLite TF2234MC-B1X 22" 1920x1080 5ms VGA DVI USB Touchscreen IPS LED Monitor
Quicklinx: B1JYWS00 Mfr#: TF2234MC-B1X
ProLite TF2234MC uses Projective Capacitive Touch technology, built into an eye catching bezel with edge-to-edge glass. Featuring IPS LCD Screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for Interactive Digital Signage. In addition to the superb image quality, the screen comes with an IP54 Rating, making it dust and water resistant and with a rugged bezel making it suitable for demanding environments. The ProLite TF2234MC is the ideal screen for the kiosk integrators and a solution for interactive digital signage, instore retail, gaming and interactive presentations.
Iiyama ProLite TF2234MC-B1X - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5" - touchscreen
Touch-screen
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.247 mm
Brightness
225 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Screen Coating
7H Hard Coating
51.75 cm x 4.6 cm x 31.35 cm
4.4 kg
VCCI, VESA DPMS, IP54, TUV Bauart
Display Type
Diagonal Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.247 mm
Brightness
225 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 82.3 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, input select, colour temperature, phase, H-size
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
Edge-to-edge glass, HID Compliant, Projected Capacitive Touch (PCT) technology
4.4 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
DVI-D , VGA , USB
Mechanical
Flat Panel Mount Interface
100 x 100 mm
Water-resistant, dust-resistant
1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x USB cable
Power Supply
External
DC 12 V
27 Watt
B1JY C2G 2m USB 2.0 A/B Cable - Black In Stock £3.02
B1JY C2G 5m USB 2.0 A/B Cable - Black In Stock £4.29
B1JY C2G 2-Port USB 2.0 Manual Switch In Stock £16.36
B1JY C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.41
B1JY C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.45
B1JY C2G 12m USB 2.0 A/A Active Extension Cable In Stock £14.97
