Your basket is empty
iiyama ProLite TF2234MC-B1 22" 1920x1080 5ms VGA DVI-D LED Black Monitor with Speakers
Quicklinx: 8WB3WS00 Mfr#: TF2234MC-B
ProLite TF2234MC uses Projective Capacitive Touch technology, built into an eye catching bezel with Edge to Edge glass. Featuring IPS LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for interactive digital signage. In addition to the superb image quality, the screen comes with an IP54 rating, making it dust and water resistant and with a rugged bezel making it suitable for demanding environments. The screen also features a vast array of inputs including DVI as well as USB for the Touch sensor itself, and a high definition 1920 x 1080 resolution. The ProLite TF2234MC is the ideal for the kiosk integrators and a solution for interactive digital signage, instore retail, gaming and interactive presentations.
Iiyama ProLite TF2234MC-B1 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22" - touchscreen
Touch-screen
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.247 mm
Brightness
225 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Screen Coating
7H Hard Coating
51.75 cm x 4.6 cm x 31.35 cm
5.1 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, VESA DPMS, IP54, TUV Bauart
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.247 mm
Brightness
225 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 82.3 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, colour temperature, H-size
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
5.1 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
DVI-D , VGA , USB
Mechanical
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), water-resistant, dust-resistant
1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x USB cable
Power Supply
External
40 Watt
Included Software
Drivers & Utilities
ENERGY STAR Certified
