iiyama ProLite TF2215MC-B1 21.5" 1920x1080 14ms HDMI VGA DisplayPort LED Monitor
Quicklinx: DKJSWS00 Mfr#: TF2215MC-B1
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 14ms
Speakers: [N/A]
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£334.28 ex VAT
£401.13 inc VAT
The ProLite TF2215MC-B1 (21.5 inch) uses PCAP touch technology and is built into an eye-catching bezel with edge-to-edge glass. Thanks to a glass overlay covering the screen and a rugged bezel, it guarantees high durability and scratch-resistance, making it perfect for kiosk and high use public facing applications.
Equipped with a foam seal finish it supports seamless integration into kiosks and provides IP65 rating resulting in dust and water resistance from the front. Landscape, portrait and face-up orientation ensures flexible mounting possibilities in almost any installation. For ease of integration, the TF2215MC-B1 comes equipped with external mounting brackets making it an ideal solution for kiosk integrators, industrial environments, control rooms and interactive multimedia.
  • IP
    The IP code classifies and rates the degree of protection against water intrusion. IP65 means that the monitor is protected to water splashes against the enclosure from any direction.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen.
iiyama ProLite TF2215MC-B1 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5" - touchscreen
Energy Class
Class A
Energy Consumption per Year
30 kWh
Power Consumption (On mode)
21 W
Touch-screen
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Screen Coating
7H Hard Coating
31.5 cm x 4.25 cm x 51.99 cm
4.4 kg
DDC-2B, VESA DPMS, CB, cULus, TUV Bauart, CU
Display Type
Energy Class
Class A
30 kWh
21 W
Diagonal Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Brightness w/touchscreen
215 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
14 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
OSD Languages
English, French, Italian, Spanish, Dutch, Japanese, Chinese
Edge-to-edge glass, HID Compliant, scratch-resistant, Projected Capacitive Touch (P-CAP) technology, landscape mode, portrait mode, Face Up mode
4.4 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , DisplayPort , HDMI , USB , Audio line-out
Mechanical
VESA Mounting Interface
100 x 100 mm
IP65 protection
Remote control
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable
19 Watt
Included Software
Drivers & Utilities
Microsoft Windows CE, Linux, Apple MacOS X, Microsoft Windows Vista / XP, Microsoft Windows 7 / 8 / 10
iiyama ProLite TF2215MC-B1 21.5 Bundle deal on iiyama ProLite TF2215MC-B1 21.5" 1920x1080 14ms HDMI VGA DisplayPort LED Monitor
£433.45
Response Time: 14ms
Speakers: [N/A]
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 300 - 500
