iiyama ProLite TF1934MC-B5X 19" 1280x1024 14ms HDMI VGA DisplayPort LED Monitor
Quicklinx: DKJPWS00 Mfr#: TF1934MC-B5X
The ProLite TF1934MC multi-touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The IPS matrix guarantees high performance with accurate and consistent color reproduction and wide viewing angles. The touch function remains unaffected even if the glass is scratched.
  • IPS
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • Capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen.
iiyama ProLite TF1934MC-B5X - LED monitor - 19"
LED-backlit LCD monitor - 19" - touchscreen
Touch-screen
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
SXGA 1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Matte black
41.6 cm x 4.65 cm x 34.4 cm
4.4 kg
Plug and Play, DDC-2B, CB, cULus, TUV Bauart, IP65, CU
Display Type
Diagonal Size
19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
SXGA 1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Brightness w/touchscreen
225 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
14 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
31.4 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
HDCP, scratch-resistant
Matte black
4.4 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , DisplayPort , HDMI , USB
Mechanical
VESA Mounting Interface
100 x 100 mm
Cable cover
Mounting Kit
Included
Power Consumption (Typical)
15 Watt
Power Consumption Stand by
2 Watt
Included Software
Drivers & Utilities
