Your basket is empty
iiyama ProLite TF1934MC-B2X 19" 1280x1024 5ms VGA DVI USB Touchscreen LED Monitor
Price Drop! Was £456.79 inc VAT!
Price Drop
Clearance
Last Few Remaining
Quicklinx: B1JXWS00 Mfr#: TF1934MC-B2X
The ProLite TF1934MC-B2X 19" multi touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The IPS matrix guarantees high performance with accurate and consistent color reproduction, and wide viewing angles. The touch function remains unaffected even if the glass is scratched. The screen is IP65 rated which means it is dust and water resistant. For ease of installation in any environment the ProLite TF1934MC-B2X comes equipped with external mounting brackets making it an ideal solution for kiosk integrators and Instore Retail.
Iiyama ProLite TF1934MC-B2X - LED monitor - 19"
LED-backlit LCD monitor - 19" - touchscreen
Touch-screen
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
225 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Screen Coating
7H Hard Coating
41.6 cm x 4.65 cm x 34.45 cm
4.5 kg
VESA DPMS, CB, cULus, TUV Bauart, IP65
Display Type
Diagonal Size
19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
225 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
14 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.4 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, input select, colour temperature, phase, H-size
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
Scratch-resistant
4.5 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , DVI-D , USB
Mechanical
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x USB cable
Mounting Kit
Included
Power Supply
Internal
20 Watt
Power Consumption Stand by
2 Watt
Included Software
Drivers & Utilities
B1JX C2G 2m USB 2.0 A/B Cable - Black In Stock £3.02
B1JX C2G 5m USB 2.0 A/B Cable - Black In Stock £4.24
B1JX C2G 2-Port USB 2.0 Manual Switch In Stock £16.25
B1JX C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.34
B1JX C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.75
B1JX C2G 12m USB 2.0 A/A Active Extension Cable In Stock £14.89
