The ProLite multi touchscreen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched.
- iiyama ProLite TF1734MC-B6X - LED monitor - 17"
- LED-backlit LCD monitor - 17" - touchscreen
- Energy Class
- Class E
- Power Consumption (On mode)
- 12.7 W
- Touch-screen
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 75 Hz
- Pixel Pitch
- 0.264 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Black, matte
- 36.9 cm x 4.75 cm x 30.7 cm
- 3.6 kg
- Plug and Play, DDC-2B, CB, cULus, TUV Bauart, IP65, CU, REACH SvHC
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 17"
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- Pixel Pitch
- 0.264 mm
- Brightness
- 350 cd/m²
- Brightness w/touchscreen
- 315 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 31.4 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- OSD Languages
- English, German, French, Italian, Spanish, Japanese, Chinese
- HDCP, OSD lock, HID Compliant, scratch-resistant, anti-fingerprint, glove touch mode
- Black, matte
- 3.6 kg
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- DisplayPort , VGA , USB , HDMI
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- 90% light transmittance
- Cables Included
- 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
- Mounting Kit
- Included
- 12.7 W
- Power Consumption SDR (On mode)
- 12.7 kWh/1000h
- Power Consumption (Typical)
- 13 Watt
- Power Consumption Stand by
- 2 Watt
- 2 Watt
- Included Software
- Drivers & Utilities
- OS Required
- Linux, Microsoft Windows
- Limited warranty - 3 years
