iiyama ProLite TF1734MC-B5X 17" 1280x1024 5ms HDMI VGA DisplayPort LED Monitor
Quicklinx: DKJMWS00 Mfr#: TF1734MC-B5X
Diagonal Size: 17in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, HDMI, VGA (HD-15)
Hurry, only 1 left in stock!
£379.64 ex VAT
£455.56 inc VAT
The ProLite TF1734MC 17" multi touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. The screen is IP65 rated which means it is dust and water resistant. For ease of installation in any environment the ProLite TF1734MC comes equipped with external mounting brackets making it an ideal solution for kiosk integrators and instore retail.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen.
  • Open frame brackets
    This open frame monitor comes equipped with external mounting brackets. It guarantees easy installation and makes it an ideal solution for kiosk integrators and instore retail.
  • IP code
    The IP code classifies and rates the degree of protection against water intrusion. IP65 means that the monitor is protected to water splashes against the enclosure from any direction.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • LED backlit
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO friendly product.
iiyama ProLite TF1734MC-B5X - LED monitor - 17"
LED-backlit LCD monitor - 17" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Black, matte
36.9 cm x 4.75 cm x 30.7 cm
3.6 kg
Plug and Play, DDC-2B, CB, cULus, TUV Bauart, IP65, CU
Display Type
Diagonal Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Brightness w/touchscreen
225 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
31.4 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
HDCP, 10-point multi-touch, scratch-resistant, Projected Capacitive Touch (P-CAP) technology, glove touch mode
Black, matte
3.6 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
DisplayPort , VGA , USB , HDMI
Mechanical
VESA Mounting Interface
100 x 100 mm
90% light transmittance
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable
20 Watt
Power Consumption Stand by
2 Watt
Included Software
Drivers & Utilities
iiyama ProLite TF1734MC-B5X 17 Bundle deal on iiyama ProLite TF1734MC-B5X 17" 1280x1024 5ms HDMI VGA DisplayPort LED Monitor
£478.81
Diagonal Size: 17in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 300 - 500
