iiyama ProLite TF1734MC-B1X 17" 1280x1024 5ms VGA DVI USB Touchscreen LED Monitor
Quicklinx: B1JWWS00 Mfr#: TF1734MC-B1X
The ProLite TF1734MC 17" multi touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. The screen is IP65 rated which means it is dust and water resistant. For ease of installation in any environment the ProLite TF1734MC comes equipped with external mounting brackets making it an ideal solution for kiosk integrators and Instore Retail.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball.
  • Open frame
    Open frame monitors come equipped with external mounting brackets making them an ideal solution for kiosk integrators and Instore Retail.
  • IP65
    The IP Code classifies how resistant a device is to foreign objects and moisture. IP65 means the monitor is completely dust tight and will resist water jets.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • LED-backlit
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
iiyama ProLite TF1734MC-B1X - LED monitor - 17"
LED-backlit LCD monitor - 17" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
225 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Screen Coating
7H Hard Coating
36.9 cm x 4.75 cm x 30.7 cm
3.6 kg
VESA DPMS, CB, IP54, TUV Bauart
Display Type
Diagonal Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
225 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.4 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, input select, colour temperature, phase, H-size
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
10-point multi-touch, scratch-resistant
3.6 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
DVI-D , VGA , USB
Mechanical
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x USB cable
Mounting Kit
Included
Security Slot Type
Kensington security slot
Power Supply
External
20 Watt
Power Consumption Stand by
2 Watt
Included Software
Drivers & Utilities
Microsoft Windows 95/98, Microsoft Windows CE, Linux, Microsoft Windows 2000 / NT4.0, Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
B1JW C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
B1JW C2G 5m USB 2.0 A/B Cable - Black In Stock £5.24
B1JW C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £13.54
B1JW C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.74
B1JW C2G USB Superbooster Extender Kit In Stock £40.11
