iiyama ProLite TF1634MC-B6X 16" 1366x768 8ms VGA HDMI DisplayPort LED Monitor
Quicklinx: FJ2JWS00 Mfr#: TF1634MC-B6X
Diagonal Size: 15.6in
Max Resolution: 1366 x 768
Response Time: 8ms
Speakers: None
Interfaces: DisplayPort, HDMI, VGA (HD-15)
Hurry, only 2 left in stock!
£346.37 ex VAT
£415.64 inc VAT
The ProLite multi touchscreen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched.
iiyama ProLite TF1634MC-B6X - LED monitor - 15.6"
LED-backlit LCD monitor - 15.6" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.252 mm
Brightness
400 cd/m²
Contrast Ratio
500:1
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Black, matte
38.1 cm x 4.6 cm x 23.05 cm
3.5 kg
Plug and Play, DDC-2B, CB, cULus, TUV Bauart, IP65, CU, REACH SvHC
3-year warranty
Display Type
Diagonal Size
15.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.252 mm
Brightness
400 cd/m²
Brightness w/touchscreen
360 cd/m²
Contrast Ratio
500:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.4 - 60.3 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
Bezel Type
Flat front
HDCP, OSD lock, HID Compliant, scratch-resistant, anti-fingerprint, glove touch mode
Black, matte
3.5 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
DisplayPort , VGA , USB , HDMI
Mechanical
VESA Mounting Interface
100 x 100 mm
90% light transmittance
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Mounting Kit
Included
16 Watt
Power Consumption Stand by
2 Watt
Power Consumption (Off Mode)
2 Watt
Included Software
Drivers & Utilities
Limited warranty - 3 years
Response Time: 8ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 300 - 500
