iiyama ProLite TF1534MC-B5X 15" 1024x768 8ms VGA HDMI DisplayPort Touchscreen LED Monitor
Quicklinx: DY9QWS00 Mfr#: TF1534MC-B5X
The ProLite TF1534MC-B5X 15" multi touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. The screen is IP65 rated which means it is dust- and water-resistant from the front. For ease of installation in any environment the ProLite TF1534MC-B5X comes equipped with external mounting brackets making it an ideal solution for kiosk integrators and in-store retail.
  • Capacitive touch technology
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus pen.
  • Open frame brackets
    This open frame monitor comes equipped with external mounting brackets. It guarantees easy installation and makes it an ideal solution for kiosk integrators and in-store retail.
  • IP65 rated
    IP65 means that the monitor is protected to water splashes against the enclosure from any direction.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
iiyama ProLite TF1534MC-B5X - LED monitor - 15"
LED-backlit LCD monitor - 15" - touchscreen
Touch-screen
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
370 cd/m²
Contrast Ratio
700:1
Response Time
8 ms
Colour Support
16.2 million colours
Input Connectors
HDMI, VGA, DisplayPort
Screen Coating
Matte
Voltage
AC 120/230 V
Matte black
33.75 cm x 4.45 cm x 26.55 cm
2.7 kg
Plug and Play, DDC-2B, CB, cULus, TUV Bauart, IP65, EAC
Display Type
Diagonal Size
15"
Panel Type
TN
Aspect Ratio
4:3
Native Resolution
1024 x 768
Pixel Pitch
0.297 mm
Brightness
370 cd/m²
Brightness w/touchscreen
330 cd/m²
Contrast Ratio
700:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
31 - 60 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese
HDCP, Eco-Mode
Matte black
2.7 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , DisplayPort , HDMI , USB
Mechanical
VESA Mounting Interface
100 x 100 mm
IP65 protection, 90% light transmittance
1 x HDMI cable - 1.8 m , 1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Mounting Kit
Included
Input Voltage
AC 120/230 V
Power Consumption (Typical)
9 Watt
Power Consumption Stand by
2 Watt
Included Software
Driver
5 °C
35 °C
20 - 80% (non-condensing)
