The ProLite TF1534MC 15" multi-touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The higher brightness ensures crispy and clear image, resulting in outstanding information transmission performance, even in bright environment. The touch function remains unaffected even if the glass is scratched. The screen is dust- and water-resistant.
Capacitive touch technology
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball. -
Open frame
Open frame monitor is an ideal solution for kiosk integrators and in-store retail. -
Scratch-resistance
Scratch-resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched. -
LED-backlit monitor
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true eco-friendly product.
- iiyama ProLite TF1534MC-B1X - LED monitor - 15"
- LED-backlit LCD monitor - 15" - touchscreen
- Touch-screen
- Panel Type
- TN
- Aspect Ratio
- 4:3
- Native Resolution
- 1024 x 768
- Pixel Pitch
- 0.264 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Screen Coating
- 7H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 33.75 cm x 4.45 cm x 26.55 cm
- 2.7 kg
- DDC-2B, VESA DPMS, CB, cULus, TUV Bauart, IP65
- Display Type
- Diagonal Size
- 15"
- Panel Type
- TN
- Aspect Ratio
- 4:3
- Native Resolution
- 1024 x 768
- Pixel Pitch
- 0.264 mm
- Brightness
- 350 cd/m²
- Brightness w/touchscreen
- 315 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 31.4 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Screen Coating
- 7H Hard Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, input select, colour temperature, phase, H-size
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
- A-Si technology
- Black
- 2.7 kg
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- DVI-D , VGA , USB (Type B)
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x USB cable
- Mounting Kit
- Included
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Stand by
- 2 Watt
- Included Software
- Driver
- OS Required
- Microsoft Windows 95/98, Microsoft Windows CE, Linux, Microsoft Windows 2000 / NT4.0, Apple MacOS X, Microsoft Windows 2000/XP/Vista/7/8
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
