iiyama ProLite TF1515MC-B1 15" LED Display
Quicklinx: DKJRWS00 Mfr#: TF1515MC-B1
£344.69 ex VAT
£413.62 inc VAT
The ProLite TF1515MC-B1 (15 inch) uses PCAP touch technology and is built into an eye-catching bezel with edge-to-edge glass. Thanks to a glass overlay covering the screen and a rugged bezel, it guarantees high durability and scratch-resistance, making it perfect for kiosk and high use public facing applications. Equipped with a foam seal finish it supports seamless integration into kiosks and provides IP65 rating resulting in dust and water resistance from the front. Landscape, portrait and face-up orientation ensures flexible mounting possibilities in almost any installation.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen.
  • Open frame brackets
    This open frame monitor comes equipped with external mounting brackets. It guarantees easy installation and makes it an ideal solution for kiosk integrators and Instore Retail.
  • IP
    The IP code classifies and rates the degree of protection against water intrusion. IP65 means that the monitor is protected to water splashes against the enclosure from any direction.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • Foam seal
    A foam seal finish (8mm) around the monitor ensures seamless integration and optimal dust protection.
iiyama ProLite TF1515MC-B1 15" LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
15"
Commercial Use
Yes - digital signage
Resolution
1024 x 768
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15), HDMI, DisplayPort
TN+Film
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
4:3
TV Tuner
No tuner
Speaker System
Speakers not included
USB
Remote control, remote control
Energy Class
Class A
16 Watt
Power Consumption (On mode)
11 W
Power Consumption Stand by
1.2 Watt
Energy Consumption per Year
15 kWh
29.1 cm x 4.15 cm x 36.4 cm
2.9 kg
Energy Class
Class A
16 Watt
11 W
15 kWh
Diagonal Class
15"
Commercial Use
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
Modes
Portrait mode, landscape mode, Face-up Mode
Protection
Anti-scratch display
Dimensions
Without stand
29.1 cm
4.15 cm
36.4 cm
2.9 kg
Enclosure Colour
Display
LCD Display Technology
TN+Film
Resolution
1024 x 768
Image Aspect Ratio
4:3
Edge-lit LED
Coating
7H Hard
Image Contrast Ratio
800:1
Brightness
350 cd/m²
Viewing Angle
160 degrees
Viewing Angle (Vertical)
150 degrees
Touchpoints Qty
10
Response Time
8 ms
Display Menu Language
English, French, Italian, Spanish, Dutch, Japanese, Chinese
3M Projected Capacitive Technology (PCAP)
Stands & Mounts
Flat Panel Mount Interface
100 x 100 mm
Media Player
USB Port
Remote Control
Remote control
Audio System
Speaker System
Connector Type
VGA input , DisplayPort input , HDMI , USB , Audio line-out
Remote control
DisplayPort cable , USB cable , HDMI cable
DDC-2B, VESA DPMS, CB, cULus, TUV Bauart, IP65, CU
Power supply
1.2 Watt
Brand: iiyama
