iiyama ProLite TF1015MC-B2 10.1" 1280x800 25ms VGA HDMI DisplayPort Touch LED Monitor
Quicklinx: FJ2NWS00 Mfr#: TF1015MC-B2
Diagonal Size: 10.1in
Max Resolution: 1280 x 800
Response Time: 25ms
Speakers: None
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£276.57 ex VAT
£331.88 inc VAT
The ProLite TF1015MC (10.1 inch) uses PCAP touch technology and is built into an eye catching bezel with edge-to-edge glass. Thanks to a glass overlay covering the screen and a rugged bezel, it guarantees high durability and scratch-resistance, making it perfect for kiosk and high use public facing applications. Equipped with a foam seal finish it supports seamless integration into kiosks and provides IP65 rating resulting in dust and water resistance from the front. Landscape, portrait and face-up orientation ensures flexible mounting possibilities in almost any installation. For ease of integration, the TF1015MC comes equipped with external mounting brackets making it an ideal solution for kiosk integrators, industrial environments, control rooms and interactive multimedia.
iiyama ProLite TF1015MC-B2 - LED monitor - 10.1"
LED-backlit LCD monitor - 10.1" - touchscreen
Energy Class
Class E
Power Consumption (On mode)
8.1 W
Touch-screen
Panel Type
VA
Aspect Ratio
16:10
Native Resolution
720p 1280 x 800 at 60 Hz
Pixel Pitch
0.1695 mm
Brightness
500 cd/m²
Contrast Ratio
1300:1
Response Time
25 ms
Input Connectors
HDMI, VGA, DisplayPort
26.05 cm x 3.95 cm x 18.35 cm
1.4 kg
Plug and Play, DDC-2B, CB, cULus, REACH, TUV Bauart, IP65, SVHC, CU
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
10.1"
Panel Type
VA
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.1695 mm
Brightness
500 cd/m²
Brightness w/touchscreen
450 cd/m²
Contrast Ratio
1300:1
Response Time
25 ms
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
31.4 - 49.7 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
170
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
HDCP, edge-to-edge glass, OSD lock, scratch-resistant, anti-fingerprint, Projected Capacitive Touch (P-CAP) technology, landscape mode, portrait mode, Face Up mode
1.4 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , DisplayPort , HDMI , USB , Audio line-out
Mechanical
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), rugged, foam lining, IP65 protection
Remote control, stylus
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Mounting Kit
Included
Security Slot Type
Kensington security slot
8.1 W
8.1 kWh/1000h
Power Consumption (Typical)
10 Watt
Power Consumption Stand by
1.2 Watt
Power Consumption (Off Mode)
1.2 Watt
Included Software
Drivers & Utilities
Limited warranty - 3 years
Response Time: 25ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
