The TE8668MIS-B1AG is a perfect solution for educational and corporate use. Its 85.6" infrared 20-point touchscreen allows users to make annotations on files, opened directly from a USB device or internal memory. The display also supports playback of presentations, high-resolution video and almost any other type of content, stored on a USB device or internal memory.
The high-quality commercial IPS LCD screen with a 4K Ultra HD resolution (3840 x 2160 - 8.3MP) and a high contrast ratio enables stunning images with superb image quality from anywhere in the class room or meeting room. The anti-glare coating drastically reduces ambient reflection in high-brightness environments without compromising the sharpness and clarity of the image. The screen has a 24/7 nonstop operating time and is equipped with thick glass to ensure a long durability in high-use environments, such as class rooms or meeting rooms.
Touch technology - infrared
The infrared technology uses infrared backlight. A touch event is registered with great accuracy, when the infrared light is blocked by finger or stylus. This technology does not rely on an overlay or substrate, so it is impossible to physically "wear out" the touchscreen. Moreover the display characteristics remain virtually unaffected by the touch functionality. -
4K
Ultra HD resolution (3840 x 2160), better known as 4K, offers a gigantic viewable area with more information and work space. Due to the high DPI (dots per inch), it displays an incredibly sharp and crisp image. -
AG coating
The anti-glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks. -
24/7
24/7 displays are designed for a continuos operation. -
USB playback
The monitor supports playback of presentations, video and almost any type of content, stored on the USB device or internal memory.
- iiyama ProLite TE8668MIS-B1AG 86" Class (85.6" viewable) LED-backlit LCD display - 4K - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen (multi touch)
- Diagonal Class
- 86"
- Diagonal Size
- 85.6"
- Commercial Use
- Yes - interactive
- Black
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15), DisplayPort
- Technology
- IPS
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- 2 ports
- Included Accessories
- Remote control, 3 Touch styluses, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class C
- 410 Watt
- Power Consumption (On mode)
- 410.3 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 599 kWh
- 198.85 cm x 10.05 cm x 116.1 cm
- 76 kg
- Product Type
- Energy Class
- Class C
- 410 Watt
- 410.3 W
- 599 kWh
- Diagonal Class
- 86"
- Diagonal Size
- 85.6"
- Commercial Use
- Yes - interactive
- Combined With
- Touchscreen (multi touch)
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- Modes
- Landscape mode
- Cooling System
- Fanless
- 198.85 cm
- 10.05 cm
- 116.1 cm
- 76 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Direct-lit LED
- Coating
- Anti-glare, 7H Hard
- Image Contrast Ratio
- 1200:1
- Brightness
- 375 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 20
- Response Time
- 8 ms
- Display Menu Language
- Czech, English, German, French, Italian, Polish, Russian, Dutch
- Certified for 24/7 Continuous Operation, infrared multitouch technology
Stands & Mounts
- Flat Panel Mount Interface
- 800 x 600 mm
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 24 Watt
- Speakers
- 2 x main channel speaker - 12 Watt
- Connector Type
- VGA input , 3 x HDMI , DisplayPort input , Composite video input , Digital audio output (optical) , HDMI output , Audio input , RS-232C , LAN , 2 x touch in
- 3 Touch styluses, batteries
- Cables Included
- VGA cable , HDMI cable , DisplayPort cable , USB cable
- VESA DPMS, CB, TUV Bauart
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
