iiyama ProLite TE7568MIS-B1AG 75" 3840x2160 4K UHD Interactive Display
Quicklinx: D36XWS00 Mfr#: TE7568MIS-B1AG
The TE7568MIS-B1AG is a perfect solution for educational and corporate use. Its 75" infrared 20-point touchscreen with integrated interactive Note writing software allows users to make annotations on files opened directly from a USB device or internal memory. The display also supports the playback of presentations, video and almost any other type of content stored on a USB device or internal memory.
The high quality commercial IPS LCD screen with a 4K UHD resolution (3840 x 2160 - 8.3 megapixel) guarantees stunning images with superb image quality from anywhere in the class room or meeting room. The anti-glare coating drastically reduces ambient reflection in high brightness environments without compromising image clarity and sharpness. The screen has a 24/7 non-stop operating time and is equipped with 4 mm thick glass to ensure a long durability in high-use environments like a class room or meeting room.
  • Touch technology - Infrared
    The infrared technology uses infrared backlight. A touch event is registered with great accuracy when the infrared light is blocked by finger or stylus. This technology does not rely on an overlay or substrate, so it is impossible to physically "wear out" the touchscreen. Moreover the display characteristics remain virtually unaffected by the touch functionality.
  • 4K
    UHD resolution (3840 x 2160), better known as 4K, offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI (dots per inch), it displays an incredibly sharp and crisp image.
  • IPS
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • AG coating
    The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
iiyama ProLite TE7568MIS-B1AG 75" Class (74.5" viewable) LED display - 4K
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
75"
Diagonal Size
74.5"
Commercial Use
Yes - interactive
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
2 ports
Remote Control
Standard remote
Voltage
Energy Class
Class C
332 Watt
Power Consumption (On mode)
331.9 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
485 kWh
176.35 cm x 10.05 cm x 101.65 cm
56 kg
Energy Class
Class C
332 Watt
331.9 W
485 kWh
Diagonal Class
75"
Diagonal Size
74.5"
Commercial Use
Yes - interactive
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
Modes
Landscape mode
Cooling System
Fanless
176.35 cm
10.05 cm
101.65 cm
56 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare
Image Contrast Ratio
1200:1
Brightness
350 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Touchpoints Qty
20
Response Time
8 ms
Display Menu Language
Czech, English, German, French, Italian, Polish, Russian, Dutch
Certified for 24/7 Continuous Operation, infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
800 x 400 mm
Media Player
USB Port
USB Ports Qty
2
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
24 Watt
Speakers
2 x main channel speaker - built-in - 12 Watt
Connector Type
VGA input , 3 x HDMI , DisplayPort input , Composite video input , Digital audio output (optical) , HDMI output , Audio input , RS-232C , Network , 2 x touch in
Cable ties, 3 Touch styluses, batteries
VGA cable , HDMI cable , DisplayPort cable , USB cable
DDC-2B, CB, TUV Bauart, CU
Power supply
Nominal Voltage
0.5 Watt
