iiyama ProLite TE7503MIS-B1AG 75" 3840x2160 6ms VGA HDMI DisplayPort IPS LED Large Format Display
Quicklinx: FF7YWS00 Mfr#: TE7503MIS-B1AG
TV Tuner Presence: No
Video Interface: HDMI
£2,249.41 ex VAT
£2,699.29 inc VAT
Share your vision with the ProLite TE7503MIS-B1AG - a perfect solution for educational and corporate use. Its large infrared 20-point touchscreen features Note, web browser, file manager, cloud drives, WPS office and ScreenSharePro. It comes with dual touch pens, allowing users to annotate easily in 4K on files and on-screen content which can be saved directly on a USB device, internal memory or on a connected cloud drive. The display supports playback of presentations, high-resolution video and almost any other type of content.
The high-quality commercial IPS LCD screen with a 4K UHD resolution, 350cd/m2 and a contrast ratio of 1100:1 provides vibrant, detailed and high-quality images from anywhere in the class or meeting room. The anti-glare coating drastically reduces ambient reflection in high-brightness environments without compromising the sharpness and clarity of the image. The screen has a 24/7 non-stop operating time and is equipped with an all-metal bezel, 4 mm thick hardened glass to ensure long durability in high-use environments such as classrooms or meeting rooms.
  • Infrared touch technology
    This technology uses infrared backlight. A touch event is registered with great accuracy when the infrared light is blocked by finger or stylus. This technology does not rely on an overlay or substrate, so it is impossible to physically "wear out" the touchscreen. Moreover the display characteristics remain virtually unaffected by the touch functionality.
  • 4K resolution
    The Ultra HD resolution, better known as 4K, offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI, it displays an incredibly sharp and crisp image.
iiyama ProLite TE7503MIS-B1AG 75" Class (74.5" viewable) LED-backlit LCD display - 4K
LED-backlit LCD flat panel display with built-in media player and touchscreen (multi touch)
Diagonal Class
75"
Diagonal Size
74.5"
Commercial Use
Yes - interactive
Matte black
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
HDMI
HDMI Ports Qty
3 ports
Wi-Fi, LAN
PC Interface
VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Storage Drive Capacity
32 GB
Storage Capacity
32 GB
USB
2 ports
Remote control, 2 styluses, batteries
Voltage
Energy Class
Class B
Power Consumption (On mode)
218.5 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
319 kWh
Energy Class
Class B
218.5 W
319 kWh
Diagonal Class
75"
Diagonal Size
74.5"
Commercial Use
Yes - interactive
Combined With
Built-in media player and touchscreen (multi touch)
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
3 ports
PC Interface
Modes
Landscape mode, kiosk mode
Cooling System
Fanless
Enclosure Colour
Matte black
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare, 7H Hard
Image Contrast Ratio
1100:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
20
Response Time
6 ms
Display Menu Language
Czech, English, German, French, Italian, Polish, Russian, Dutch
Infrared multitouch technology, Expansion Slot, designed for 24/7 operation, tempered glass (4mm)
Stands & Mounts
Flat Panel Mount Interface
800 x 400 mm
VESA Compatibility
Media Player
USB Port
USB Ports Qty
2
Configuration
ARM Cortex-A73 Dual-Core + ARM Cortex-A53 Dual-Core - 4 GB - 32 GB - Mali-G51
32 GB
Operating System
Android OS
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Functionality
WEB browsing, cloud storage playback
Wi-Fi, LAN
Wi-Fi Protocol
802.11b, 802.11g, 802.11n, 802.11a, 802.11ac
Connect & Share
Screen Share
Connector Type
VGA input , 3 x HDMI , DisplayPort input , Audio input , RS-232 , Network , HDMI output , SPDIF output , Audio output , USB 2.0 - bottom , USB 3.0 - top , 2 x USB 3.0 - side
HDMI cable , USB cable
Plug and Play, DDC-2B, CB, WEEE, REACH, TUV Bauart, ERP, EAC
Power supply
Input Voltage
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Brand: iiyama
Price Range Ex VAT: £1500+
