The TE6568MIS-B1AG is a great display for educational and corporate use. Its 64.5'' infrared 20-point touchscreen allows users to make annotations on files, opened directly from a USB device or internal memory. The display also supports playback of presentations, high-resolution video and almost any other type of content, stored on a USB device or internal memory.
The high-quality commercial IPS LCD screen with a 4K resolution (3840 x 2160 - 8.3MP) and a high contrast ratio enables stunning images with superb image quality from anywhere in the class or meeting room. The anti-glare coating drastically reduces ambient reflection in high brightness environments without compromising the sharpness and clarity of the image. The screen has a 24/7 nonstop operating time and is equipped with thick glass to ensure a long durability in high-use environments, such as class rooms or meeting rooms. There are no shadows or reductions in image performance to contend with.
Touch technology - infrared
The infrared technology uses infrared backlight. A touch event is registered with great accuracy, when the infrared light is blocked by finger or stylus. This technology does not rely on an overlay or substrate, so it is impossible to physically "wear out" the touchscreen. Moreover the display characteristics remain virtually unaffected by the touch functionality. -
4K
Ultra HD resolution (3840 x 2160), better known as 4K, offers a gigantic viewable area with more information and work space. Due to the high DPI (dots per inch), it displays an incredibly sharp and crisp image. -
IPS
IPS technology offers higher contrast, darker blacks and much better viewing angles. The screen will look good, no matter what angle you look at it. -
AG coating
The anti-glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
- iiyama ProLite TE6568MIS-B1AG 65" Class (64.5" viewable) LED display
- Product Type
- LED-backlit LCD flat panel display with touchscreen (multi touch)
- Diagonal Class
- 65"
- Diagonal Size
- 64.5 in
- Commercial Use
- Yes - interactive communication
- Black
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15), DisplayPort
- Technology
- IPS
- LCD Backlight Technology
- LED backlight - direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- 2 ports
- Remote Control
- Standard remote
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- Power Consumption (On mode)
- 205.4 W
- Energy Consumption per Year
- 300 kWh
- 152.141 cm x 9.885 cm x 89.741 cm
- 45 kg
- Product Type
- Energy Class
- Class B
- 205.4 W
- 300 kWh
- Diagonal Class
- 65"
- Diagonal Size
- 64.5 in
- Commercial Use
- Combined with
- Touchscreen (multi touch)
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- Modes
- Landscape mode
- Cooling System
- Fanless
- 152.141 cm
- 9.885 cm
- 89.741 cm
- 45 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Coating
- Anti-glare, 7H Hard
- Image Contrast Ratio
- 1200:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 20
- Response Time
- 8 ms
- Display Menu Language
- Czech, English, German, French, Italian, Polish, Russian, Dutch
- Certified for 24/7 Continuous Operation, infrared multitouch technology
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Standard remote
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 24 Watt
- Speakers
- 2 x main channel speaker - built-in - 12 Watt
- Connector Type
- VGA input , 3 x HDMI , DisplayPort input , Composite video input , Digital audio output (optical) , HDMI output , Audio input , RS-232C , Network , 2 x touch in
- Included Accessories
- 3 Touch styluses, batteries
- Cables Included
- VGA cable , HDMI cable , DisplayPort cable , USB cable
- VESA DPMS, CB, TUV Bauart, CU
- Power Device
- Power supply
- Nominal Voltage
- Power Consumption Stand by
- 0.5 Watt
