iiyama ProLite TE6568MIS-B1AG 65" 3840x2160 4K Ultra UHD Interactive Display
Quicklinx: D44HWS00 Mfr#: TE6568MIS-B1AG
TV Tuner Presence: No
Video Interface: Composite, HDMI
More than 50 in stock
£1,645.88 ex VAT
£1,975.05 inc VAT
The TE6568MIS-B1AG is a great display for educational and corporate use. Its 64.5'' infrared 20-point touchscreen allows users to make annotations on files, opened directly from a USB device or internal memory. The display also supports playback of presentations, high-resolution video and almost any other type of content, stored on a USB device or internal memory.
The high-quality commercial IPS LCD screen with a 4K resolution (3840 x 2160 - 8.3MP) and a high contrast ratio enables stunning images with superb image quality from anywhere in the class or meeting room. The anti-glare coating drastically reduces ambient reflection in high brightness environments without compromising the sharpness and clarity of the image. The screen has a 24/7 nonstop operating time and is equipped with thick glass to ensure a long durability in high-use environments, such as class rooms or meeting rooms. There are no shadows or reductions in image performance to contend with.
  • Touch technology - infrared
    The infrared technology uses infrared backlight. A touch event is registered with great accuracy, when the infrared light is blocked by finger or stylus. This technology does not rely on an overlay or substrate, so it is impossible to physically "wear out" the touchscreen. Moreover the display characteristics remain virtually unaffected by the touch functionality.
  • 4K
    Ultra HD resolution (3840 x 2160), better known as 4K, offers a gigantic viewable area with more information and work space. Due to the high DPI (dots per inch), it displays an incredibly sharp and crisp image.
  • IPS
    IPS technology offers higher contrast, darker blacks and much better viewing angles. The screen will look good, no matter what angle you look at it.
  • AG coating
    The anti-glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
iiyama ProLite TE6568MIS-B1AG 65" Class (64.5" viewable) LED display
LED-backlit LCD flat panel display with touchscreen (multi touch)
Diagonal Class
65"
Diagonal Size
64.5 in
Commercial Use
Yes - interactive communication
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
2 ports
Remote Control
Standard remote
Voltage
Energy Class
Class B
Power Consumption (On mode)
205.4 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
300 kWh
152.141 cm x 9.885 cm x 89.741 cm
45 kg
Energy Class
Class B
205.4 W
300 kWh
Diagonal Class
65"
Diagonal Size
64.5 in
Commercial Use
Combined with
Touchscreen (multi touch)
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
Modes
Landscape mode
Cooling System
Fanless
152.141 cm
9.885 cm
89.741 cm
45 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Coating
Anti-glare, 7H Hard
Image Contrast Ratio
1200:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
20
Response Time
8 ms
Display Menu Language
Czech, English, German, French, Italian, Polish, Russian, Dutch
Certified for 24/7 Continuous Operation, infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
2
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
24 Watt
Speakers
2 x main channel speaker - built-in - 12 Watt
Connector Type
VGA input , 3 x HDMI , DisplayPort input , Composite video input , Digital audio output (optical) , HDMI output , Audio input , RS-232C , Network , 2 x touch in
3 Touch styluses, batteries
VGA cable , HDMI cable , DisplayPort cable , USB cable
VESA DPMS, CB, TUV Bauart, CU
Power supply
Nominal Voltage
0.5 Watt
Video Interface: HDMI
Brand: iiyama
Price Range Ex VAT: 1500+
