iiyama ProLite TE6503MIS-B1AG 65’’ 3840x2160 6ms VGA HDMI USB IPS LED Large Format Display
Quicklinx: FC2DWS00 Mfr#: TE6503MIS-B1AG
Share your vision with the ProLite TE6503MIS-B1AG - a perfect solution for educational and corporate use. Its large infrared 20-point touchscreen features Note, web browser, file manager, cloud drives, WPS office and ScreenSharePro. It comes with dual touch pens, allowing users to annotate easily in 4K on files and on-screen content which can be saved directly on a USB device, internal memory or on a connected cloud drive. The display supports playback of presentations, high-resolution video and almost any other type of content.
The high-quality commercial IPS LCD screen with a 4K UHD resolution, 350cd/m2 and a contrast ratio of 1200:1 provides vibrant, detailed and high-quality images from anywhere in the class or meeting room. The anti-glare coating drastically reduces ambient reflection in high-brightness environments without compromising the sharpness and clarity of the image. The screen has a 24/7 non-stop operating time and is equipped with an all-metal bezel, 4 mm thick hardened glass to ensure long durability in high-use environments such as classrooms or meeting rooms.
  • Infrared touch technology
    This technology uses infrared backlight. A touch event is registered with great accuracy when the infrared light is blocked by finger or stylus. This technology does not rely on an overlay or substrate, so it is impossible to physically "wear out" the touchscreen. Moreover the display characteristics remain virtually unaffected by the touch functionality.
  • 4K resolution
    The Ultra HD resolution, better known as 4K, offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI, it displays an incredibly sharp and crisp image.
iiyama ProLite TE6503MIS-B1AG 65" Class (64.5" viewable) LED-backlit LCD display - 4K - for interactive communication
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
65"
Diagonal Size
64.5"
Commercial Use
Yes - interactive
Matte black
Platform
Android
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
Wi-Fi, LAN
PC Interface
VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote control, 2 touch pens, batteries
Voltage
Diagonal Class
65"
Diagonal Size
64.5"
Commercial Use
Yes - interactive
Combined With
Touchscreen
Platform
Android
Operating System
Android OS
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
Modes
Landscape mode
Design
Thin Bezel Design
Cooling System
Fanless
Enclosure Colour
Matte black
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Direct-lit LED
Coating
Anti-glare, 7H Hard
Image Contrast Ratio
1200:1
Dynamic Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
20
Response Time
6 ms
Display Menu Language
Czech, English, German, French, Italian, Polish, Russian, Dutch
Certified for 24/7 Continuous Operation, infrared multitouch technology, integrated iiWare 8.0 software
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
VESA Compatibility
Media Player
USB Port
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Functionality
Streaming media playback
Wi-Fi, LAN
Connector Type
VGA input , 3 x HDMI , DisplayPort input , Composite video input , Digital audio output (optical) , HDMI output , Audio input , RS-232C , LAN , 2 x touch in , 4 x USB 2.0
HDMI cable , USB cable
Plug and Play, DDC-2B, WEEE, REACH, TUV Bauart, ERP
Power supply
Input Voltage
