Incorporating the InfraRed 10 point touch feature along with supreme IPS panel color performance, this display offers the optimum performance for a truly multi-user interactive experience. With the ability to handle up to 10 individual touch points, the TE5564MIS-B2AG offers an exceptional capacity within retail, education, training, corporate and B2B markets. Features include PIP and PBP perfect for Video Conferencing or handing multi-input content in many environments. It also features an ambient light sensor delivering optimal picture quality with the added benefit of saving on power.
IPS
IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
Touch technology - infrared
The infrared technology uses infrared backlight. A touch event is registered with great accuracy when the infrared light is blocked by finger or stylus. This technology does not rely on an overlay or substrate, so it is impossible to physically "wear out" the touchscreen. Moreover the display characteristics remain virtually unaffected by the touch functionality. -
AG coating
The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks. -
PIP
PIP (Picture in Picture) function allows you to watch images coming from two different sources at the same time. -
Light sensor
The ambient light sensor detects changes in environmental lighting conditions and automatically adjusts the screens backlight brightness to compensate for an increase or decrease in light.
- iiyama ProLite TE5564MIS-B2AG 55" Class (54.6" viewable) LED-backlit LCD display - Full HD
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, composite, HDMI, S-Video
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, pen stylus
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A
- 143 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 127.1 cm x 11.05 cm x 74.2 cm
- 40.8 kg
- Product Type
- Energy Class
- Class A
- 143 Watt
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Modes
- Landscape mode
- Protection
- Protection glass
- Dimensions
- Without stand
- 127.1 cm
- 11.05 cm
- 74.2 cm
- 40.8 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-glare
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 1400:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.63 x 0.63mm
- Touchpoints Qty
- 10
- Response Time
- 8 ms
- Display Menu Language
- English, German, French, Polish, Russian, Spanish, Dutch
- Colour Temperature Control
- Infrared multitouch technology
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Remote Control
- Remote control
Audio System
- Audio Controls
- Sound mode, balance, bass, treble
- Speaker System
- 2 speakers
- Output Power / Total
- 24 Watt
- Speakers
- 2 x main channel speaker - 12 Watt
- Connector Type
- 2 x HDMI , DVI-D input , VGA input , VGA output , Serial input , Serial output , Component video input , S-Video input , Composite video input , Composite video output , Audio line-in , Audio output , Audio input , USB , LAN , DisplayPort input , DVI-D output , Speakers output
- Pen stylus
- Cables Included
- VGA cable , DVI cable , USB cable
- DDC-2B, VESA DPMS, CB, TUV Bauart
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- On / Off Switch
