iiyama ProLite T3234MSC-B2 32" 1920x1080 6.5 VGA DVI Touchscreen LED Large Format Display
Quicklinx: B1K9WS00 Mfr#: T3234MSC-B2
  • 1080p
ProLite T3234MSC uses projective capacitive touch technology, built into an eye catching bezel with edge to edge glass. Featuring VA LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for interactive digital signage. In addition to the superb image quality, the screen comes with a rugged bezel making it suitable for demanding environments. The screen also features a vast array of inputs including DVI as well as USB for the touch sensor itself, and a high definition 1920 x 1080 resolution. The ProLite T3234MSC is the ideal solution for interactive digital signage, instore retail, kiosks, gaming and interactive presentations.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball.
  • FULL HD
    With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
  • VESA
    VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard.
  • VA
    VA technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Speakers
    Built-in stereo speakers deliver rich sound.
iiyama ProLite T3234MSC-2 32" Class (31.5" viewable) LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
32"
Diagonal Size
31.5"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
PC Interface
DVI, VGA (HD-15)
VA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Voltage
65 Watt
Power Consumption Stand by
2 Watt
78.15 cm x 6.95 cm x 47.65 cm
16.2 kg
65 Watt
Diagonal Class
32"
Diagonal Size
31.5"
Commercial Use
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
PC Interface
DVI, VGA (HD-15)
78.15 cm
6.95 cm
47.65 cm
16.2 kg
Enclosure Colour
Display
LCD Display Technology
VA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
7H Hard
Colour Depth
16.7 million colours
Image Contrast Ratio
3000:1
Brightness
315 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.364 x 0.364mm
Response Time
6.5 ms
Multitouch
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Audio System
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x speaker - 8 Watt
Network & Internet Multimedia
Connect & Share
USB Human Interface Device (HID)
Connector Type
VGA input , DVI-D input
DDC-2B, VESA DPMS, TUV Bauart, IPX1
Power supply
Input Voltage
2 Watt
B1K9 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
