ProLite T3234MSC uses projective capacitive touch technology, built into an eye catching bezel with edge to edge glass. Featuring VA LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for interactive digital signage. In addition to the superb image quality, the screen comes with a rugged bezel making it suitable for demanding environments. The screen also features a vast array of inputs including DVI as well as USB for the touch sensor itself, and a high definition 1920 x 1080 resolution. The ProLite T3234MSC is the ideal solution for interactive digital signage, instore retail, kiosks, gaming and interactive presentations.
Touch technology - capacitive
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball. -
FULL HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor. -
VESA
VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard. -
VA
VA technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
Speakers
Built-in stereo speakers deliver rich sound.
- iiyama ProLite T3234MSC-2 32" Class (31.5" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- PC Interface
- DVI, VGA (HD-15)
- Technology
- VA
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Voltage
- AC 120/230 V (50/60 Hz)
- 65 Watt
- Power Consumption Stand by
- 2 Watt
- 78.15 cm x 6.95 cm x 47.65 cm
- 16.2 kg
- Product Type
- 65 Watt
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- PC Interface
- DVI, VGA (HD-15)
- 78.15 cm
- 6.95 cm
- 47.65 cm
- 16.2 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- VA
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- 7H Hard
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 3000:1
- Brightness
- 315 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.364 x 0.364mm
- Response Time
- 6.5 ms
- Multitouch
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 200 mm
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 16 Watt
- Speakers
- 2 x speaker - 8 Watt
Network & Internet Multimedia
- Connect & Share
- USB Human Interface Device (HID)
- Connector Type
- VGA input , DVI-D input
- DDC-2B, VESA DPMS, TUV Bauart, IPX1
- Power Device
- Power supply
- Input Voltage
- 2 Watt
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
