Your basket is empty
iiyama ProLite T3234MSC-B2 32" 1920x1080 6.5 VGA DVI Touchscreen LED Large Format Display
Quicklinx: B1K9WS00 Mfr#: T3234MSC-B2
  • 1080p (Full HD)
ProLite T3234MSC uses projective capacitive touch technology, built into an eye catching bezel with edge to edge glass. Featuring VA LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for interactive digital signage. In addition to the superb image quality, the screen comes with a rugged bezel making it suitable for demanding environments. The screen also features a vast array of inputs including DVI as well as USB for the touch sensor itself, and a high definition 1920 x 1080 resolution. The ProLite T3234MSC is the ideal solution for interactive digital signage, instore retail, kiosks, gaming and interactive presentations.
Iiyama ProLite T3234MSC-2 32" Class (31.5" viewable) LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
32"
Diagonal Size
31.5 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
PC Interface
DVI, VGA (HD-15)
VA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Voltage
65 Watt
78.15 cm x 6.95 cm x 47.65 cm
16.2 kg
65 Watt
Diagonal Class
32"
Diagonal Size
31.5 in
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
PC Interface
DVI, VGA (HD-15)
78.15 cm
6.95 cm
47.65 cm
16.2 kg
Enclosure Colour
Display
LCD Display Technology
VA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
7H Hard
Colour Depth
16.7 million colours
Image Contrast Ratio
3000:1
Brightness
315 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.364 x 0.364mm
Response Time
6.5 ms
Multitouch
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Audio System
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x speaker - built-in - 8 Watt
Network & Internet Multimedia
Connect & Share
USB Human Interface Device (HID)
Connector Type
VGA input , DVI-D input
DDC-2B, VESA DPMS, TUV Bauart, IPX1
Power supply
Nominal Voltage
Power Consumption Stand by
2 Watt
B1K9 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.02
B1K9 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.29
B1K9 C2G 2-Port USB 2.0 Manual Switch In Stock £16.36
B1K9 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.41
B1K9 C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.45
B1K9 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £14.97
