iiyama ProLite T2735MSC-B2 27" 1920x1080 5ms VGA DVI HDMI Touchscreen LED Monitor
Quicklinx: BKT1WS00 Mfr#: T2735MSC-B2
With 1920 x 1080 Full HD resolution and projective capacitive 10 point touch technology, the ProLite T2735MSC delivers seamless and accurate touch response. Featuring AMVA+ LED-backlit LCD screen technology, it offers exceptional color performance and wide viewing angles, making it an excellent choice for a vast array of demanding interactive applications. Users can benefit from its hinged stand allowing the monitor to lay down completely flat for use as a giant tablet. The T2735MSC comes equipped with several video inputs and a USB 3.0 HUB as well as stereo speakers delivering good quality sound. An ideal screen for interactive digital signage, instore retail, gaming and interactive presentations purposes.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched.
  • AMVA+
    AMVA+ Panel technology offers 24 bit "True Color" performance and amazing viewing angles.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • Blue light reducer
    As we all know looking at a monitor screen for several hours per day, especially form a closer distance, causes eye fatigue. This effect is much stronger with computer screens than with TV equipment. One of the factors responsible for this phenomenon is the blue light emitted by the screen. Therefore reducing the amount of blue light ultimately allows our eyes to feel less tired while working long hours with a computer screen. They achieved it by adjusting the monitor's brightness and color temperature through a feature called & ldquo; Blue light reduction & rdquo; easily accessible through the monitor's OSD menu.
iiyama ProLite T2735MSC-B2 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Touch-screen, microphone, camera, USB 3.0 hub
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
255 cd/m²
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
5 ms (grey-to-grey), 12 ms (typical)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, HDMI (MHL)
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
Voltage
AC 100/240 V (50/60 Hz)
67.25 cm x 5 cm x 41.9 cm
8.2 kg
DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B
3-year warranty
Display Type
Energy Class
Class B
Diagonal Size
27"
Built-in Devices
Microphone, camera, USB 3.0 hub
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
255 cd/m²
Brightness w/touchscreen
220 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, input select, colour temperature, phase, clock, blue reduction
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
Eco-Mode, Advanced Contrast Ratio (ACR), HID Compliant, 10-point multi-touch, blue light reduction
8.2 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
Touch-screen
Movement Detection Technology
Projected capacitive
VGA , DVI-D , MHL / HDMI , Headphones , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , Audio line-in
Mechanical
Tilt
Tilt Angle
+15/+70
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), built-in adjustable tilt stand
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
36 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Linux, Microsoft Windows Vista, Microsoft Windows 7 / Windows 8
Limited warranty - 3 years
5 °C
35 °C
10 - 80% (non-condensing)
Accessories (4)
BKT1 StarTech.com Dual Monitor Mount - Stackable In Stock £226.92
BKT1 StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
BKT1 StarTech.com Monitor Arm - Heavy Duty In Stock £93.49
BKT1 StarTech.com Monitor Desk Mount - Steel In Stock £50.26
Other bundles (1)
BKT1 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
