With 1920 x 1080 Full HD resolution and projective capacitive 10 point touch technology, the ProLite T2735MSC delivers seamless and accurate touch response. Featuring AMVA+ LED-backlit LCD screen technology, it offers exceptional color performance and wide viewing angles, making it an excellent choice for a vast array of demanding interactive applications. Users can benefit from its hinged stand allowing the monitor to lay down completely flat for use as a giant tablet. The T2735MSC comes equipped with several video inputs and a USB 3.0 HUB as well as stereo speakers delivering good quality sound. An ideal screen for interactive digital signage, instore retail, gaming and interactive presentations purposes.
Touch technology - capacitive
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. -
AMVA+
AMVA+ Panel technology offers 24 bit "True Color" performance and amazing viewing angles. -
Scratch resistance
Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched. -
Blue light reducer
As we all know looking at a monitor screen for several hours per day, especially form a closer distance, causes eye fatigue. This effect is much stronger with computer screens than with TV equipment. One of the factors responsible for this phenomenon is the blue light emitted by the screen. Therefore reducing the amount of blue light ultimately allows our eyes to feel less tired while working long hours with a computer screen. They achieved it by adjusting the monitor's brightness and color temperature through a feature called & ldquo; Blue light reduction & rdquo; easily accessible through the monitor's OSD menu.
- iiyama ProLite T2735MSC-B2 - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Touch-screen, microphone, camera, USB 3.0 hub
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.311 mm
- Brightness
- 255 cd/m²
- Contrast Ratio
- 3000:1 / 12000000:1 (dynamic)
- Response Time
- 12 ms (typical); 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, HDMI (MHL)
- Tilt
- Screen Coating
- 7H Hard Coating
- Black
- 67.25 cm x 5 cm x 41.9 cm
- 8.2 kg
- DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B
- Display Type
- Energy Class
- Class B
- Diagonal Size
- 27"
- Viewable Size
- 27"
- Built-in Devices
- Microphone, camera, USB 3.0 hub
- Panel Type
- A-MVA+
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 255 cd/m²
- Brightness w/touchscreen
- 220 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 24 - 80 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Screen Coating
- 7H Hard Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, H/V position, input select, colour temperature, phase, clock, blue reduction
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
- Eco-Mode, Advanced Contrast Ratio (ACR), HID Compliant, 10-point multi-touch, blue light reduction
- Black
- 8.2 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
Input
- Touch-screen
- Movement Detection Technology
- Projected capacitive
- VGA , DVI-D , MHL / HDMI , Headphones , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- +15/+70
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), built-in adjustable tilt stand
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x SuperSpeed USB cable
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 100/240 V (50/60 Hz)
- 36 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Driver
- OS Required
- Linux, Microsoft Windows Vista, Microsoft Windows 7 / Windows 8
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£483.33
Accessories (4)
StarTech.com Dual Monitor Mount - Stackable | In Stock | £146.29 |
StarTech.com Cubicle Monitor Hanger | In Stock | £45.29 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £50.91 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £72.79 |
Other bundles (6)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G 0.5m Select High Speed HDMI with Ethernet | In Stock | £6.31 |
C2G 5m Select High Speed HDMI with Ethernet | In Stock | £21.05 |
C2G 10m Select High Speed HDMI with Ethernet | In Stock | £40.43 |
C2G 15m Select High Speed HDMI with Ethernet | In Stock | £54.75 |
C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black | In Stock | £14.57 |
