iiyama ProLite T2454MSC-B1AG 23.8" 1920x1080 5ms VGA HDMI Touchscreen LED Monitor
Quicklinx: DXPVWS00 Mfr#: T2454MSC-B1AG
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: HDMI, VGA (HD-15)
17 in stock
£242.32 ex VAT
£290.78 inc VAT
With its Full HD (1920x1080) resolution and accurate Projective Capacitive 10 point touch technology, the ProLite T2454MSC-B1AG delivers seamless and accurate touch response. Featuring IPS LCD screen technology, it offers exceptional color performance and wide viewing angels, making it a perfect choice for a vast array of interactive applications. The Anti-glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. Its flexible stand can be positioned at several angles creating a comfortable and ergonomic user experience. The ProLite T2454MSC-B1AG is the ideal solution for interactive signage, instore retail, POS and interactive presentations.
  • Capacitive touch technology
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus pen.
  • Anti-glare coating
    The Anti-glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
  • IPS technology
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
iiyama ProLite T2454MSC-B1AG - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8" - touchscreen
Energy Class
Class A
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
Touch-screen, stylus, USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Height, tilt
Screen Coating
Matte
Matte black
54.05 cm x 12.8 cm x 38.8 cm
5.5 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC-2B, CB, RoHS, WEEE, REACH, TUV Bauart, ERP, VCCI Class B, EAC
Display Type
Energy Class
Class A
35 kWh
24 W
Diagonal Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese
HDCP, Eco-Mode, anti-glare, Advanced Contrast Ratio (ACR), i-Style Color, ultra-thin bezel design
Matte black
5.5 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
Touch-screen, stylus - touchscreen
Movement Detection Technology
Capacitive
VGA , HDMI , 2 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Audio line-in (mini-jack) , Headphones (mini-jack)
Mechanical
Height, tilt
Tilt Angle
- 5/+90
Height Adjustment
70 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.8 m , 1 x USB cable - 1.8 m , 1 x HDMI cable - 1.8 m
MTBF
30,000 hour(s)
Security Slot Type
Kensington security slot
24 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
ENERGY STAR Certified
5 °C
35 °C
10 - 80% (non-condensing)
iiyama ProLite T2454MSC-B1AG 23.8 Bundle deal on iiyama ProLite T2454MSC-B1AG 23.8" 1920x1080 5ms VGA HDMI Touchscreen LED Monitor
£341.49
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 150 - 300
