iiyama ProLite T2336MSC-B2AG 23" 1920x1080 5ms VGA DVI HDMI Monitor
Quicklinx: CW4FWS00 Mfr#: T2336MSC-B2AG
Diagonal Size: 23in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
10 in stock
£309.69 ex VAT
£371.62 inc VAT
With its Full HD resolution and accurate Projective Capacitive 10-point touch technology, the ProLite T2336MSC delivers seamless and accurate touch response. The IPS panel technology guarantees high performance with excellent color reproduction and high contrast, making it an excellent choice for a vast array of demanding interactive applications. The anti-glare coating helps to avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. Its flexible stand can be positioned at several angles creating a comfortable and ergonomic user experience.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (gloved or not) and magnetic ball.
  • IPS technology
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • AG coating
    The anti-glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • High-quality stereo speakers
    This LED monitor is equipped with two high-quality stereo speakers.
iiyama ProLite T2336MSC-b2AG - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23" - touchscreen
Energy Class
Class B
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
25.3 W
Touch-screen, USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 7H Hard Coating
56.1 cm x 25.4 cm x 37.9 cm
6.3 kg
VCCI, VESA DPMS, PSE Mark, TUV Bauart, CU
Display Type
Energy Class
Class B
37 kWh
25.3 W
Diagonal Size
23"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Brightness w/touchscreen
213 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
Backlight Technology
LED backlight
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Japanese
Eco-Mode, Advanced Contrast Ratio (ACR), HID Compliant, blue light reduction, i-Style Color
6.3 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
DVI-D , VGA , HDMI , Audio line-in , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A)
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
1 x DVI cable , 1 x VGA cable , 1 x audio cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
26 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Microsoft Windows 7 / Windows 8
iiyama ProLite T2336MSC-B2AG 23 Bundle deal on iiyama ProLite T2336MSC-B2AG 23" 1920x1080 5ms VGA DVI HDMI Monitor
£408.86
Diagonal Size: 23in
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 300 - 500
