iiyama Prolite T2252MTS-B3 22" Multi Touch 1920x1080 2ms VGA DVI-D HDMI LED Monitor
Quicklinx: 93W2WS00 Mfr#: T2252MTS-B3
The ProLite T2252MTS is a 22" two-point multi-touch monitor based on the Optical Touch Screen technology with a 1920 x 1080 high definition LCD screen.
It has outstanding features i.e. 1000:1 contrast ratio, 260 cd/m2 brightness and 2 ms response time. Moreover, the T2252MTS is Windows 7 Compatible and ready for the emerging business and consumer software packages. The multi touch function is supported only under Windows 7. The monitor lets you browse the web, email and draw while working on multiple screens, docking or typing on the on-screen keyboard. You can scroll and rotate pictures, draw, zoom in and out using certain tap, flick, grab and pincer gestures. The multi-touch is not only fast but also fun to work with. HDMI, DVI and analog inputs are available for flexible connectivity, along with USB for the touch interface.
  • X Res
    A typical LCD uses four backlight lamps. By reducing this number to two only, Iiyama has managed not only to considerably lower the power consumption, but also to reduce the CO2 emission into the environment making this LCD a true ECO-Friendly product.
  • LED-backlit
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
  • ACR (Advanced Contrast Ratio)
    Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • HDMI (High-Definition Multimedia Interface)
    HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
  • OverDrive on/off
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
iiyama ProLite T2252MTS-3 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22" - touchscreen
Energy Class
Class A
Energy Consumption per Year
30 kWh
Power Consumption (On mode)
20.2 W
Touch-screen
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
220 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
51.65 cm x 24 cm x 37.75 cm
5.1 kg
Environmental Standards
ENERGY STAR Qualified
DDC-2B, VESA DPMS, GOST-R, TUV Bauart
Display Type
Energy Class
Class A
30 kWh
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
220 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Colour balance, input select
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), single touch: XP/Vista, multi touch: Windows 7/8 (HID)
5.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Optical
VGA , DVI-D , HDMI (HDCP) , Headphones , USB
Mechanical
Tilt
Tilt Angle
-9/+22
VESA Mounting Interface
100 x 100 mm
Stand, stylus
1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
20.2 W
Power Consumption (Typical)
19 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Sustainability Information
ENERGY STAR Certified
93W2 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
