iiyama ProLite T2252MSC-B1 21.5" 1920x1080 7ms VGA HDMI DP Monitor
Quicklinx: CW4BWS00 Mfr#: T2252MSC-B1
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 7ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
16 in stock
£185.19 ex VAT
£222.22 inc VAT
With its Full HD (1920x1080) resolution and accurate Projective Capacitive 10 point touch technology, the ProLite T2252MSC-B1 delivers seamless and accurate touch response. Featuring IPS LCD screen technology, it offers exceptional color performance and wide viewing angels, making it a perfect choice for a vast array of interactive applications. The flexible stand can be positioned at several angels creating a comfortable and ergonomic user experience. In addition, the edge-to-edge glass and ultra slim design creates an eye-catching finish. The ProLite T2252MSC-B1 is the ideal solution for interactive signage, instore retail, POS and interactive presentations.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and magnetic ball.
  • IPS technology
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Scratch resistance
    Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
  • Blue light reducer
    Looking at a monitor screen for several hours per day, especially form a closer distance, causes eye fatigue. This effect is much stronger with computer screens than with TV equipment. One of the factors responsible for this phenomenon is the blue light emitted by the screen. Therefore reducing the amount of blue light ultimately allows eyes to feel less tired while working long hours with a computer screen. It was achieved by adjusting the monitor's brightness and color temperature through a feature called "Blue light reduction" easily accessible through the monitor's OSD menu.
  • VESA
    VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard.
iiyama ProLite T2252MSC-B1 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22" - touchscreen
Energy Class
Class F
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
17.8 W
Touch-screen
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
7H Hard Coating
Voltage
49.05 cm x 22.05 cm x 37.05 cm
2.16 kg
DDC-2B, VESA DPMS, cULus, TUV Bauart, CU
3-year warranty
Display Type
Energy Class
Class F
38 kWh
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Vertical Refresh Rate
55 - 76 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Dutch, Japanese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), X-Res Technology, scratch-resistant, Projected Capacitive Touch (P-CAP) technology
2.16 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
Touch-screen - touchscreen
VGA , DisplayPort , HDMI (HDCP) , Headphones , USB
Mechanical
Tilt
Tilt Angle
-3/+73
VESA Mounting Interface
100 x 100 mm
Stand
1 x VGA cable , 1 x HDMI cable , 1 x audio cable
Security Slot Type
Kensington security slot
Input Voltage
17.8 W
17.8 kWh/1000h
Power Consumption (Typical)
18.1 Watt
Power Consumption Stand by
0.5 Watt
Microsoft Windows Vista / 7 / 8 / 8.1 / 10
Limited warranty - 3 years
Diagonal Size: 22in
Response Time: 7ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Stock Status: In stock
